Slipping, Miss-firing HELP!!!
Started by ghollis_84, April 1, 2006, 23:42
ghollis_84
Hi Guys,
After having a great meet, i get home and car is all fine, I have just be called out and tha car is Awful! it feels like it is slipping when trying to accelerate or a constant miss fire, i hope it will get me home,
Can anyone help me out with this issue, does anyone know what it could be?
Grant
Red MR-S, TRD Stage 1 kit, plate V* MRS, AEM Induction Kit, TTE Springs, Pre-Cats Gutted, Corky, Custom Luggage set, BAMA, 03 side vents, TRD FSB, Gun Metal grey stock wheels, Red Calipers, Club Sticker, Clear indicators, Dev\'s
sorry Grant not quite sure what you mean, are you saying that when you accelerate with your foot off the clutch pedal, the rpm rises sharply but the speed doesn't?
or
is it sluggish and having trouble accelerating
ghollis_84
Its having trouble accelerating, even if i put my foot down it still finds it really hard to pick up speed, it shakes really badly, my dad seems to think it is a miss fire, spose i will have to take it to see Mr T.
fraid i'd agree with that, if its misfireing without a CEL then theres a chance a coil pack has died, but mr.t can confirm that
should still see a cel even if teh coil has died
precats in or out?
Quote from: "markiii"should still see a cel even if the coil has died
precats in or out?
how do you know that Mark?
there are 4 lines to each coil, power, earth, ecu common and a fireing line. Yes its possible that the ECU senses the coil pack firing by knock or feedback thru the common line but do you know that for certain Mark?
I'm no expert so please correct me if i'm wrong
I'm no saying the CEL will identify teh problem, but if a coil is dead you are going to get either a misfire CEl or a knock CEl
ghollis_84
No Pre-Cats,
I have booked it in today about 4ish for them to see what the problem is, i am hoping its not going to be too pricey.
Thanx for your help guys
normanh
mmm Mis-fires I had this very recently and my local Mr T put it down to a faulty coil pack cost around £123 including labour, seems to have been a little more basic cos when I looked no 1 plug had its own private swimming pool and Mr T changed no 2 coil pack. Check theres no water in your plug recess's that will def give u mis-fires. I still cant figure out why water has got into the plugs!
normanh
Quote from: "normanh"I still cant figure out why water has got into the plugs!
Capilliary action is an amazing thing  s;) ;) s;)
Quote from: "aaronjb"Capilliary action is an amazing thing  s;) ;) s;)
tell me about it, i have a problem with capillary action every friday night  s:wink: :wink: s:wink:    s:wink: :wink: s:wink:
ghollis_84
Thanx for all you help guys, it was a Spark plug that was causing it, it was all carbed up and therefore wouldnt work, I have got them to change all 4 and all seems to be well again.
Grant
Phew...glad it's sorted mate
Grant, did you get a CEL at all?
ghollis_84
Nope no CEL, nothing to tell me it went wrong, Should it have given me one then?
Quote from: "ghollis_84"Nope no CEL, nothing to tell me it went wrong, Should it have given me one then?
well this is my point, i'm not sure it will give you one
ghollis_84
Well in my case i never sore a CEL and after reading this post yest i did have a double check and there was definately not one there. Hmmmm, does this mean my car has a fault in it which means it wont through a CEL or does this mean if a spark plug goes then it wont through a CEL, What do you think?
FWIW - When i first bought my car, one of my plugs was knackered, I had no CEL either.
no i dont think anythings wrong, i'm just not convinsed that a misfire caused by a coil or plug will trigger a CEL
ghollis_84
K Kool, Cheers for your help on this guys, puts my mind at rest for a while.
Grant
Quote from: "kanujunkie"no i dont think anythings wrong, i'm just not convinsed that a misfire caused by a coil or plug will trigger a CEL
It will if the plugs are gapped wrong  s:wink: :wink: s:wink:   s:oops: :oops: s:oops:
normanh
Welll i only mentioned water cos i ended up with a permanent cel and my Mr t diagnosed coilpack 1 and then promptly changed no 2 leaving me with a wet plug body up to half way up the coilpack which i suspect was the problem all along. I replaced the plugs before the coilpack was changed only taking it back to dealer because i thought he knew best daaaaaaaaaaaaa!!!!!!!!!!!
normanh
upset 2 owner to say the least!!!!!!
