sequential transmission oil recommend!
Started by Anonymous, September 23, 2003, 02:50
Me it searches the transmission oil of the my mr2 spyder. But, it is not easy. Because the possibility of searching [sequential transmission oil for mr2spyder]  it is because is not.   s:cry: :cry: s:cry:
Recommendation do as a favor. Best regards!   s:D :D s:D
Redline MT90  s:) :) s:)
Isn't the transmission itself the same as the manual one?
mph
The SMT hydraulic fluid is proprietary Toyota and also very expensive. However I would not risk using anything else for the SMT.
Gearbox oil specification is in your Owner's Manual. Many people (at least for the MR2 mk2) use Redline MT90 as Tem writes.
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Quote from: "mph"The SMT hydraulic fluid
Good catch, I assumed he meant the gearbox oil...
"Gearbox oil specification is in your Owner's Manual. Many people (at least for the MR2 mk2) use Redline MT90"
I had that in my Mk1 MR2 and it made wonders. Now I have it in my Roadster (as the maintenance program said to change it anyway) and it made some difference. Nothing major. However I'm hopping that it will keep things in better shape than "normal" oils.
