companies who will remove precats for you
Started by kanujunkie, April 27, 2006, 19:49
Rexy2
#175
Is there any one that will take out the precats in the surry area
cabbydave
#176
Have a chat with Headcase he has a garage down that way
It's a 2+ hr trip each way to Headcase from farnborough...I've done it enough times  s:( :( s:(
Standard
#178
MrTwos in Willenhall, Wolverhampton £50 to remove the pre cats.
He did my clutch (exedy) fitted for £200 too.   s:) :) s:)
Reeflodge
#179
Anyone in the Chichester area?
Now done it myself for the price of gaskets £20!
2000 PFL Yellow MR2 Roadster
http://www.fredwoodman.co.uk
gamps
#180
Hi just wondering why people are not just replacing the manifold with a stainless steel one from eBay it's like £130 delivered.
Makes sense don't it or am I missing something?
Quote from: "gamps"Hi just wondering why people are not just replacing the manifold with a stainless steel one from eBay it's like £130 delivered.
People are  s:) :) s:)   In fact, the 130 one delivered is the expensive one and not the best one. The 90 quid one is better. But 90 quid is still more than free  s:) :) s:)
But aftermarket manifold is better than de-pre-cat
gamps
#182
£90 one I haven't found this yet? Lol and they are asking companies to remove so still paying for it.
Quote from: "gamps"£90 one I haven't found this yet? Lol and they are asking companies to remove so still paying for it.
Not everybody is a born spanner monkey. So having it done with a replacement manifold would cost labour + manifold. Otherwise it would just be labour.
Kylemilne
#184
Right I'm new to all this and not ATALL a mechanical guy
What are the key benefits to removing the precat?
Anywhere is east Scotland that would do it ? And what price? And do I need to purchase any parts whether needed or recommended
Hi Kyle
Have a peek at this thread : all is explained
 l viewtopic.php?t=11393 l
mickeyfish
#186
called to a company in leeds today. he said around £100 to gut a pre cat.,,,,rising sun motors ( japanes and toyota specialists) leeds 12 holbeck.
sussex
#187
Quote from: "nobber"
Quote from: "MilesH"For anyone around Swindon / Cirencester area it's worth a call to Castle Eaton Vehicle Services (MR2 Specialist) - 01285 810808
Cannot fault the guy. 2 snapped studs, gen gasket, a quick look around and found a leaky rad (which is covered under warranty from the garage i bought it from) all for 56 quid !!
Highly recommended
 Just had my pre-cats removed today by Jon at Castle Eaton Vehicle services, 01285 810808, proper old school mechanic/Engineer, Mr2 specialist,(Toyota Trained) Worth travelling as you know it will be done right, Thanks Jon and the Team.   s:D :D s:D
mr2garageswindon
#188
Quote from: "sussex"
Highly recommended
No problem at all! Thanks for bringing the car along to us. Hope the wheel balance also made for smoother journey home!
Cheers.
Jon
Steveohim
#189
Is there anywhere in Gloucester, also if I take out the pre cats will it pass mot?
It will not fail due to removal of pre cats.
Other things ????
Steveohim
#191
Great thanks
darkstar
#192
Hi
Is there anybody near or in Reading, also do I have to fit de-cats? just removing pre-cats is fine?
sussex
#193
Darkstar ....... Based near Swindon , highly recommended, Just had my pre-cats removed today by Jon at Castle Eaton Vehicle services, 01285 810808, proper old school mechanic/Engineer, Mr2 specialist,(Toyota Trained) Worth travelling as you know it will be done right, Thanks Jon and the Team.   s:D :D s:D
sussex
#194
Quote from: "sussex"Darkstar ....... Based near Swindon , highly recommended, Just had my pre-cats removed today by Jon at Castle Eaton Vehicle services, 01285 810808, proper old school mechanic/Engineer, Mr2 specialist,(Toyota Trained) Worth travelling as you know it will be done right, Thanks Jon and the Team.   s:D :D s:D
Darkstar.... The garage removes the pre-cats (ceramic honeycomb and fibre material, and thats it, car runs just the same as before, no problems with MOT.
Carcotas
#195
Anyone close to Evesham ?   s:D :D s:D
Depends what you mean by close.
2 I know of:
Rogue motorsport, Southam.
Steve@d1 customs, Loughborough.
There is probably someone in birmingham, but I don't know them so can't recommend them.
Steve@D1Customs
#197
Pre cats taken out no problem, all exhaust mating surfaces thoroughly cleaned to ensure perfect gas tight seal/bolts cleaned/anti corrosive AL1100 paste applied to threads/ all nuts & bolts Torqued to correct spec/genuine new gaskets used on re-installation of manifold. full diagnostics and emissions test performed free of charge after the work has been carried out  s:) :) s:)
for peoples peace of mind i am Toyota Trained  s:) :) s:)
The Other Stu
#198
Quote from: "Steve@D1Customs"Pre cats taken out no problem, all exhaust mating surfaces thoroughly cleaned to ensure perfect gas tight seal/bolts cleaned/anti corrosive AL1100 paste applied to threads/ all nuts & bolts Torqued to correct spec/genuine new gaskets used on re-installation of manifold. full diagnostics and emissions test performed free of charge after the work has been carried out  s:) :) s:)
Steve, would you be prepared to give a rough idea of cost?
I'd like to have a go myself, but I've seen the state of my manifold bolts and I'm scared I'll do permanent damage.
Steve@D1Customs
#199
£50 plus gaskets
