Main Menu
Glossary
Started by spit, May 26, 2006, 23:07
Welcome to the MR2ROC Glossary thread.
This has been set up to bust some of the jargon encountered in the forums.
Over the coming months we'll build up the list of terms, abbreviations and acronyms. But only if you ask us to......  s:wink: :wink: s:wink:  ......So, if there's anything you'd like to see added, please post up in this thread. To keep this easy to navigate, your posts will be deleted as and when their content has been noted and/or terms have been shipped into the main listing.
Please keep this specific to the '2 and associated modifications - (we don't intend to feature acronyms of abbrevi-speak such as IMHO, LMAO etc.: you can find these almost anywhere on the interweb  s:lol: :lol: s:lol: )
Feedback always welcomed.
Enjoy!
GLOSSARY
    ABS    - Anti-Lock Brakes
    AC     - Air Conditioning
    AFR    - Air/Fuel Ratio
    BGB  - Toyota Official Workshop manual. Named "Big Green Book" as it used to be Green, currently available as 3 different sections.
    BOV   - Blow Off Valve, otherwise known as Dump Valve, vents excess Turbo pressure to extend turbo life.
    BP (Corkys)   - Breast Plate
    C2    - brand of Turbo Kit
    CAI    - Cold Air Induction
    CAT    - Catalytic Convertor
    CC     - Charge Cooler (C/C)
    CEL    - Check Engine Light
    CPS    Crankshaft Position Sensor OR Camshaft Position Sensor
    DECAT   Removal of catalytic converters in the exhaust manifold
    DOT    - Industry standard grades of brake fluid (2,3,4,5 or 5.1), named after the U.S Dept of Transport
    Dump valve    - see BOV
    ECU    - Engine Control Unit
    EGT    - Exhaust Gas Temperature
    EML     - Engine Management Light
    EMU    - Engine Management Unit
    EOBD     - European On Board Diagnostics (see also OBDII)
    EPC    - Electronic Parts Catalogue
    FL     - Facelift (later version of Roadster) Can be used to refer to parts unique to this version
    FMB    - Front Member Brace
    FPR    - Fuel Pressure Regulator
    FST    - Front Strut Tower
[brace]
GB      - Forum shorthand for "Group Buy"
Hass    - brand of Turbo Kit
Header    - American term for exhaust manifold
HEGO     - Heated Exhaust Gas Oxygen [sensor]
H/U    - Head Unit (car stereo)
IAC     - Idle Air Control (valve)
IC    - Intercooler (I/C)
IGN    - Ignition
JDM    - Japanese Domestic Market (i.e. Japanese-only parts or cars)
JOBD   - Japanese On Board Diagnostics
J-Spec - Japanese-specification (see JDM)
LCD    - Liquid Crystal Display
LED    - Light Emitting Diode
LSD    - Limited Slip Differential
LTFT     - Long Term fuel Trim
MAF    - Mass Air Flow (Sensor)
MAP    - Manifold Absolute Pressure (Sensor)
MR2 - Midship Runabout Two-Seater
MrT  -  Toyota Dealer
MSMB    - Mid Ship Member Brace
O2     - Oxygen Sensor (in the Exhaust for Emissions Control)
OBDII  - OnBoard Diagnostics (II) - the standard used to read ECU information. (II is the later European version)
OCV     - Oil Control Valve
OEM    - Original Equipment Manufacturer
PCD    - Pitch Circle Diameter (the diameter of the imaginary circle your wheel nuts sit on)
PCV    - Positive Crankcase Ventilation
PE    - Power Enterprises: a Japanese Tuning Company
PFL    - Pre Face Lift (early Roadster) Can be used to refer to parts unique to this version
P/N    - Part Number
Precat - pre-CAT (small CATs prior to the main CAT)
RLCB    - Rear Lower Cross Brace
RMB     - Rear Member Brace
RON     - Research Octane Rating (a measure of the resistance to pre-ignition of petrol)
RST     - Rear Strut Tower [brace]
SMT    - Sequential Manual Transmission
SP     - Silverstone Performance. Former Affiliate, no longer trading.
STFT    - Short Term Fuel Trim
Stoich. - Stoichiometric (the 'ideal' air/fuel ratio, or AFR = 14.7:1)
TB    - Throttle Body
TC     - Traction Control
TF300 - "The Final 300" special edition MR2s in 2006/7
TFT    - Thin Film Transistor
TPS    - Throttle Position Sensor
TRD    - Toyota Racing Development
TTE    - Toyota Team Europe
TTET    - Toyota Team Europe Turbo
VE/VME     - Volumetric Efficiency
VSV    - Vacuum Solenoid Valve
VVTi   - Variable Valve Timing-intelligent
VVTLi  - Variable Valve Timing and Lift-intelligent
WI     - Water Injection
WOT    - Wide Open Throttle
[/list]
Amendments
Added:
    27/05/06 TB
    27/05/06 DOT (thanx simonp)
    27/05/06 Header (thanx simonp)
    06/07/06 SP (thanx roger)
    02/11/06 TPS
    05/03/07 HEGO (aaronjb)
    13/09/07 FPR
    12/05/08 MSMB, BP, FST, RST, BP, FMB, RMB, RLCB
    31/12/16 various (thanks Carolyn and The Other Stu)
Edited:
    27/05/06 TFT (thanx aaronjb)
    27/05/06 PE (thanx aaronjb)
