Re-setting the ECU
Started by Anonymous, October 3, 2003, 14:50
Sorry if this is the type of question you would expect from a numpty guys    s:oops: :oops: s:oops:   but....
Is there any other way of resetting the ECU other than disconnecting the battery (Re: Slacey's cleaning your MAF thread).
Wouldn't fancy losing the stereo codes etc......    s:( :( s:(    s:( :( s:(    s:( :( s:(
Stereo codes... they'd be the special ones that you didn't know existed and can't find, only once you need 'em.
....they're the fellas   s:!: :!: s:!:    s:!: :!: s:!:    s:!: :!: s:!:
You could reset it if you had the software...  You could do a lot of other stuff as well   s:wink: :wink: s:wink:
Quote from: "Emmanuel"You could reset it if you had the software...  You could do a lot of other stuff as well   s:wink: :wink: s:wink:
ah.....
battery lead jobby it is then.......
pull the ecu fuse. that will do it.
