Replacement aerial?
Started by Anonymous, October 12, 2003, 20:37
Has anyone replaced their stock elec aerial with a bee sting/whip type aerial or does anyone know where I can get one? The only ones I can find are for roof mounting not wing mounting and the base is a bit heavy/large looking for a wing fitment. I want something as small as possible. Any help much appreciated.  s:D :D s:D
Try the one from the S2000.  It's a straight replacement, if I am not mistaken.
<edit>I hope you have enough patience because it's a real pain to work on the aerial</edit>
Didnt someone on Spyderchat sell these?
correct, sort of.
If you buy the s2000 antenna and amplified base from Honda (and it's not cheap) you can just swop them.
The chap in the US sells modifed s2000 masts that have a thread to fit the US MR2 base. Since we have motorised masts and the US (pre 2003) didn't if you bought one of these you'd also need the US MR2 base to fit it, thats about £50
 s:D :D s:D  Thanks for the help guys, I'll be down to the nearest Honda dealer tomorrow to check them out!
oops that should have read $50
Quote from: "Emmanuel"I hope you have enough patience because it's a real pain to work on the aerial
How do you get to it anyway...?
I assumed through engine bay, but doesn't look like it.
Through the sidevent...removing the inner ducting..?
(how do you remove the inner duct...bolts/clamps/where?)
Removing the inner fender..?
(I hope not, cause I can't do it right now  s:? :? s:? )
