Main Menu
SMT Pin Layout
Started by markiii, August 6, 2006, 23:30
SMT pre 03
01 LSW4 (shift lever switch)
02 LS4C (shift lever switch)
03
04
05
06
07
08
09 PACC (accumulator pressure sensor)
10 E2AC (accumulator pressure sensor)
11 VCAC (accumulator pressure sensor)
12 VCPS (GSA master pressure sensor)
13 E2PS (GSA master pressure sensor)
14 PSF (GSA master pressure sensor)
15 E2CR(GSA clutch stroke sensor)
16 VCRC (GSA clutch stroke sensor)
17 VCCR(GSA clutch stroke sensor)
18 VCSF(GSA shift stroke sensor)
19 VSFT (GSA shift stroke sensor)
20 E2SF (GSA shift stroke sensor)
21 VCSL (GSA select stroke sensor)
22 VSLT (GSA select stroke sensor)
23 E2SL(GSA select stroke sensor)
24 DSWD (door courtesy switch)
26
27
28
29
30 CAN-(engine revolution speed sensor)
31 CAN+ (engine revolution speed sensor)
32
33
34
35
36
37
38
39
40 LSW3 (shift lever switch)
41 LS3C (shift lever switch)
42 LS2C (shift lever switch)
43 SPFL (front left speed sensor)
44 SPFR (front right speed sensor)
45 SPRL (rear left speed sensor)
46 SPRR (rear right speed sensor)
47 NIP+(input shaft revolution sensor)
48 NEO (engine revolution speed sensor)
49
50
51 SFTU (transmission shift switch up)
52 SFTD (transmission shift switch down)
53
54
55
56
57 SPV+ (master solenoid)
58 SSF+ (GSA shift solenoid)
59 +B (ignition switch)
60 +B1 (ignition switch)
61 SLC- (HPU clutch solenoid)
62 SSF- (GSA shift solenoid)
63
64 SPV- (master solenoid)
65 SSL- (GSA select solenoid)
66
67 LSW1 (shift lever switch)
68 LS1C (shift lever switch)
69 LSW2 (shift lever switch)
70 STP (stop light switch)
71
72
73
74 NIP-(input shaft revolution sensor)
75
76
77
78
79
80
81
82 SSL+ (GSA select solenoid)
83 SLC+ (HPU clutch solenoid)
84 MTRL (HPU motor relay)
85
86 IG (ignition switch)
87
88 GND1
