Door open sounder
Started by Burning rubber, August 12, 2006, 13:45
Burning rubber
hi all,
does any one know how to disable the anoying bonging sound when you open a door with the key in the ignition. I have searched the forum and can't find an answer.
any help much appreciated
2005 (54) Phantom Grey, Air con, Hard top, Black leather, TM3 lip spoiler
previously
2001 (Y) Red, Air Con, Black Leather, MrT Mflaps, TTE Exhaust, Precats removed, Face lift side vents, Small Mongo\'s, Lockwood sill protectors, Mr T Mats, Red J Spec nose badge, TM3 Lip Boot Spoiler, Dev\'s Key Hole covers
2000 (W) Silver, Air con, Leather, TTE Exhaust, Hard top
enid_b
i too would like this answer, to remove the most annoying sound in the world.
cant think when i have ever actually been grateful that its been buzzin
E
evileye_wrx
It's not as bad as the Reversing sound. That really mounts my breasts!
Phil
Phil
Leeber
I thought that about the reversing sound until I realised that reverse in the SMT is actually where 1st is in most manual cars. We also have a sensible car in the household with a manual box, if I drive it too much I'm prone to getting into the '2 and trying to pull away in reverse. If it wasn't for that annoying noise my rear bumper would be a mess by now.
At least that's what I tell the other half when she suggests swapping cars for the day   s:wink: :wink: s:wink:
Also, a friend of a friend was killed in the states a couple of years ago when the car she was being driven home in was accidentally reversed over a cliff after a night out. Apparently they parked up to watch the sunrise and didn't realise that the car was in R and not D when they went to pull away!!  s:( :( s:(
Quote from: "Burning rubber"hi all,
I'd like to know how to do this too!  s:D :D s:D
heres a link to disabling the reverse beeper on an 03+
 m http://spyderchat.com/phpBB2/viewtopic. ... 15&start=0 m
and here's the disabling instructions for the door warning
 m http://spyderchat.com/phpBB2/viewtopic. ... p&start=15 m
they weren't on our forum, not that i could find anyway  s:roll: :roll: s:roll:
Excellent, thanks Stu!  s:D :D s:D
Burning rubber
The method described does not work for a 2000 model (UK) there is no connector as described.
This is my option for removing this noise pollution
The beeper is soldered onto the main clock panel, behind the speedo
1. Remove the binicle by just pulling
2. Remove the 3 screws that hold the clocks in place.
3. Now pull the clocks forward gently and unplug the 3 connectors
4. Lift the clocks out and remove the small screws from the back of the clocks
5. Now gently lift the circuit board off
The sounder is on the top left (a round object about 1" diameter)
6. I placed a piece of rubber over the sounder to mute the sound
7. Next just reverse order to put things back
This method does not stop the bleeper justs makes it very quiet
Hope this helps
previously
