Main Menu
Emanage Maps
Started by markiii, September 28, 2006, 12:48
Find below a list of emanage MAPs.
PLEASE NOTE THESE MAPS WERE TUNED FOR SPECIFIC VEHICLES WITH SPECIFIC ADD ONS AND A PARTICULAR FUEL TYPE.
MR2ROC TAKES NO RESPONSIBILITY FOR DAMAGE CAUSED WHEN USING THESE MAPS
THEY ARE INTENDED AS A GUIDE OR STARTING PLACE ONLY.
Emanage Blue
Hass Autoworks
Hass Stage II Turbo Kit running on a US 1ZZFE tuned by Hass Autoworks (MAF Pre Turbo) Setup to use the stock MAF Sensor
 m http://www.mr2roc.org/Repository/misc/referencelib ... nalmap.gsc m
Hass Stage II Turbo Kit running on a US 1ZZFE tuned by Hass Autoworks (MAF Post Turbo) Setup to use the stock MAF Sensor
 m http://www.mr2roc.org/Repository/misc/referencelib ... iginal.gsc m
Hass Stage II Turbo Kit running on a UK 1ZZFE tuned by Thor Racing (MAF Pre Turbo) Setup to use the Greddy MAP Sensor
 m http://www.mr2roc.org/Repository/misc/referencelib ... mapmap.GSC m
Hass Stage II Turbo Kit running on a UK 1ZZFE tuned by Thor Racing (MAF Post Turbo) Setup to use the Greddy MAP Sensor
 m http://www.mr2roc.org/Repository/misc/referencelib ... mapmap.gsc m
C2 Power
C2 Power Turbo Kit running on a UK 1ZZFE tuned by Thor Racing (Kit with Cast Manifold as owned by Philster_d) Setup to use the Greddy MAP Sensor
C2 Power Turbo Kit running on a J-Spec 1ZZFE tuned by C2 Power and modded by Spit (Original Kit with tubular Manifold as owned by Spit) Setup to use the stock MAF Sensor. No IGN harness. 380cc Injectors
 m http://www.mr2roc.org/Repository/misc/referencelib ... onamap.gsc m
C2 Power Turbo Kit running on a J-Spec 1ZZFE tuned by C2 Power and modded by Spit (Original Kit with tubular Manifold as owned by Spit) Setup to use the stock MAF Sensor. No IGN harness. Stock Injectors
 m http://www.mr2roc.org/Repository/misc/referencelib ... te1129.gsc m
Normally aspirated with Che manifold and Markiii pipe
 m http://www.mr2roc.org/Repository/misc/referencelib ... ex_map.gsc m
Emanage Ultimate
A map for Che manifold, lightened flywheel, big bore throttle body, Blitz lm panel filter, Markiii pipe.
 m http://www.mr2roc.org/Repository/misc/referencelib ... Engine.EM2 m
