Hass Record
Started by markiii, October 2, 2006, 11:25
Well, Tom and I stripped of his Hass kit yesterday, and I reckon thats stands us at a new record
when we fitted it record 19hours flat
when we removed it 9 hours flat, I'm getting too good at this   s:D :D s:D
Show off   s:wink: :wink: s:wink:
but removing it is a lot easier than fitting  s:wink: :wink: s:wink:
totally
no CELs then?
Nice one Mark. We should expand the "Performance Related" definition to include your spanner skills  s:lol: :lol: s:lol:
I suppose you swapped oilpans - that'd save a bit of time.
nope
we just plugged the oil return, as Tom will be needing it again soon.
N/A to Turbo to N/A in 28 hours... not bad going at all.  s8) 8) s8)
kashy
Quote from: "markiii"when we fitted it record 19hours flat
i would be happy fitting it in double that time hehe
Quote from: "kashy"
what the 9 or the 19  s:wink: :wink: s:wink:
kashy
fitting time.....
removing is easier as u dont need to owrry about where bits go etc. cant wait to get delivery and get started on the installation.
i know i know, i was just trying to pull your leg
I know where to come when I get mine then; how many hours for a C2 then Mark   s:?: :?: s:?:    s:wink: :wink: s:wink:
stopped counting Stus after Day 3   s:cry: :cry: s:cry:
though tbh now we what should be there and what shouldn't and how it's supposed to fit, baring any cockups like stripping the threads on brass fitings I reckon around 19 hours is probably doable.
Quote from: "markiii"stopped counting Stus after Day 3   s:cry: :cry: s:cry:
19x£25/hour; not bad  s:wink: :wink: s:wink:
if only  :-) :-) :-)
you guys get me cheap  s:D :D s:D
Quote from: "markiii"if only  :-) :-) :-)
you hussey!!  s:wink: :wink: s:wink:
I know but I was trying to build up your retirement business  s:wink: :wink: s:wink:
keep going it needs a lot fo building  :-) :-) :-)
and I have thought about it
Quote from: "markiii"keep going it needs a lot fo building  :-) :-) :-)
Why not; you have the facility and knowledge on the 2  s:wink: :wink: s:wink:
short answer is business and pleasure, I do this stuff to unwind, I'm not sure it would be the same
Quote from: "markiii"short answer is business and pleasure, I do this stuff to unwind, I'm not sure it would be the same
Yer but if you retire early as hoped you could do a little here and there just to tick over; not 8 hour days or anything too stressy  s:wink: :wink: s:wink:
this is true  :-) :-) :-)
I bagsy a job as spanner monkey! I even know where everything is in the garage!  s:D :D s:D
*applies for position*
how about a job as cheif chargecooler pipework mechanic, I'm going to need someone whose good with copper  :-) :-) :-)
