Will this fit?
Started by Anonymous, October 9, 2006, 12:01
willt his fit a 2
JDM Pioneer Carrozzeria CD/MD Headunit
Pioneer Carrozzeria is just a jdm line of units inc amps etc
if you have a piccy it might help?
basically most single or double din units will fit with possibly the need for an apator plates/s
its this one here
Looks like it would probably physically fit - but would likely need a custom trim ring, and wiring hacking in if there isn't an ISO connector on the back.
Just as long as you realise that without a band expander you'll only get Radio 2 on a Japanese radio in the UK (their FM band is a lot lower than ours)
as said it should fit, the band expander going to cost you about £8 and you can get the two trim pieces to go either side of the unit from toyota if it isnt the same width as standard
band expander example
 m http://cgi.ebay.co.uk/FM-Radio-Band-Exp ... dZViewItem m
