Radio Clock Display
Started by Anonymous, October 28, 2003, 19:49
2002 Model
Standard head unit
Why will the clock not change back to winter time  s:?: :?: s:?:
Still read 18:00 at 17:00 today     s:( :( s:(
As a guess have you got the radio tuned to a FM station that transmits the time signal (BBC fo instance) Most radios need that for the time function to work.
Think you also need to set the settings so that CT shows top right.  Then on an FM station for a few minutes and all should be ok.  As I understand the time signal is sent with the station information.
SimonC_Here
Think I got a duff (read old) HU in mine. No TA, no AF  s:( :( s:(  (at least the arial goes up and down when I want it to!)
I have to change the time manually. Can't quite get the Minutes right yet. must RTFM.
Simon
Tried Radio 1, 2 & BBC local radio station for 15 minutes each.
CT is on.
TP is on.
AF is on.
Time still 1 hour ahead 24 hours on from 1st post   s:? :? s:?
I can't get broadband in North Lincs, perhaps they don't broadcast fancy radio in these parts either  s:!: :!: s:!:      s:lol: :lol: s:lol:
Did you know that the pre 03 model radio clock is manually adjustable  s:?: :?: s:?:
Found out today, after i was sat in a traffic jam for an hour, so i started to fiddle with the radio. If anyone wants to know I will see which buttons i pressed & post it on here. If not i will keep it to myself  s:!: :!: s:!:
SteveJ
Quote from: "SilverMSD2"Tried Radio 1, 2 & BBC local radio station for 15 minutes each.
CT is on.
TP is on.
AF is on.
As my radio is still stuck at Salford  s:evil: :evil: s:evil:  I can't confirm this, but mine only seemed to change when it received a traffic broadcast using the CT setting
Ok, to reset the clock manually on a pre 03 model press the following buttons:
Shift
Set-up ( 8 )
Right Arrow ( 10 )
Then twist the volume control.
Hey presto     s:D :D s:D
thank you so much on your advise it worked a treat regards nidge h
dcod
 s:shock: :shock: s:shock:
Could this be the oldest ever resurrected thread? 2003!
Nidge h, I think you'll find he's 'left the building'   s:( :( s:(
