Changing the main speakers only ?
Started by Burning rubber, November 28, 2006, 11:20
Burning rubber
hi,
does anyone know if can you change the original big door speakers only and get good sound?
I am not sound expert, I would just like the sound to be a bit more bassy
cheers
2005 (54) Phantom Grey, Air con, Hard top, Black leather, TM3 lip spoiler
previously
2001 (Y) Red, Air Con, Black Leather, MrT Mflaps, TTE Exhaust, Precats removed, Face lift side vents, Small Mongo\'s, Lockwood sill protectors, Mr T Mats, Red J Spec nose badge, TM3 Lip Boot Spoiler, Dev\'s Key Hole covers
2000 (W) Silver, Air con, Leather, TTE Exhaust, Hard top
it will help, but the stock headuniot isn't very powerful so if your speaker have a low sensitivty they will be very quiet
Burning rubber
I have already changed the headunit thinking the cr** sound was a dodgy headunit.
I have fitted a Sony CDX-F5500 mp3 player which I had in my MR2 Turbo and it was very good sound.
In the Roadster it is just as useless as the stock unit
Can you suggest a reasonibly priced speaker
cheers
previously
can we also suggest you use dynamat or rubberised roofing flash tape available from B&Q, it will stop the transmission of sound through the bodywork which can make good speakers sound slightly tinny
I replaced the stock door speakers and tweeters with Infinity Kappa (ebay £100), without replacing the headunit, and for my purposes its perfect.
I did "dynamat" the door cards though with similar stuff from Matt which IMO helped tremendously, and the doors now shut with more of a solid feel - god knows what the weight has done to my 0 - 60 time though   s:wink: :wink: s:wink:
enid_b
i got a huge roll of dynamat for 20 quid at halfrauds.
made a massive difference as i had so much left i generally put it everywhere !!!
speakers, i dont think u need to spend big bucks to get a good sound, i got a set off flea bay, no big name brand, but the numbers they quoted made sense.
think i paid about 20 quid.
E
