anybody got a window switch? (passenger isde)
Started by Anonymous, December 23, 2006, 08:47
just on the off chance I know but does anyone have a passenger side window switch?  mines playing up a tad
cheers ma dears
Sorry, don't have one, but just wanted to say that you can also use the drivers side switch to replace that, if you run into one.  s8) 8) s8)
(no, the autodown won't work)
how do you work that one out then matey?
I far as I recall its a completely different plug ?  (and wire colours)
youre right Perry, different connectors
Yes, it's not plug&play, but wasn't too hard either.
IIRC, I just took the wires off the plastic connector and put them in the switch one by one. Don't remember if I got the wiring from BGB or just used a multimeter, but it must've been easy, cause I don't remember having any issues.  s8) 8) s8)
It might be your lucky day, cos I stumbled upon both switches on eBay t'other day...and for only £1.99...
 m http://cgi.ebay.co.uk/Toyota-MR2-Roadst ... dZViewItem m
If you're interested, you'll have to be quick though...there's less than a day left on them (I think)
  s:D :D s:D
Liz
Thats not the right switch for the roadster I don't believe, the window disable switch is on the dash on ours, that one is shown as being in the middle - unless it is a revision on the post 03 models
You're right Liz, that's from Celica and won't fit. I opened one hoping that I could use the switches in my '2, but they aren't even close.
(they do have auto up AND down)
Ahh...I confess I hadn't looked at it properly...fortunately, my switches are ok, so I'd skipped past it without much thought...    s:oops: :oops: s:oops:
