how many outputs???? 2000
Started by Anonymous, February 16, 2007, 15:07
hi all i want to fit the alpine sub amp 1600 to the standadr hu pre-facelift.. as this only powers the front speakers will this mean therev is a spare set of outputs for the rear channel that i will be able to use for the alpine.... also i was wanting to use the cigarette lighter output to power it...anyone ever used this before and will it work?? thanks   s:D :D s:D
patrick
If you have a high powered amp, don't run it off the cigarette lighter. You need a thick gauge cable with as short a run as possible direct to the battery with an inline fuse and another thick gauge cable to the closest good earthing point possible. There are lots of amp wiring kits around, it might make sense to get one and then you'll have all you need.
i agree with Nigel here, wire it to the cigarrette lighter socket and you run the risk of the wireing overheating and burning and dependant on the config it can do it without exceeding the 7.5amp fuse!
you'll need a seperate feed from the battery directly and a decsent earth, theres loads around in the 2. Your earth needs to be as short as possible and almost definatly under 1ft so with that in mind the best place is in the left bin or if you dont have an SMT ,under it
if you try useing the search facility theres loads of info on it
whats am smt????  s:shock: :shock: s:shock:
Jigwar
Quote from: "patrick_devereux"whats am smt????  s:shock: :shock: s:shock:
Semi-Manual Transmission. (Paddle gears)
Relevant for you since there is an SMT control box that sits under the passenger luggage bin. If you don't have one then you can use the space for an amp and as suggested get a power feed directly from the battery through the gromets on that side and find an earth on plenty of exposed metal bits under there.
HTH
steve
Jigwar
Past: \'51 plate
Present: \'06 plate TTET\'ed
aggggh i see   s:D :D s:D   thanks mate but the alpine will need to be mounted in the cabin so i can hear it bettre wont it??
Depends on how big and powerful it is. Bass is non directional ,so you could mount it anywhere as long as the volume is sufficient for you to hear it.
its the alpine SWD-1600 so not that much power realy just giving the standard speakers a hand............ anyone no the output question....cheers
filcee
Quote from: "Jigwar"Sequential Manual Transmission. (Flappy Paddle gears)
Fixed up  s;-) ;-) s;-)
Phil
2003 6-sp SMT in Sable
Jigwar
Quote from: "filcee"
Sequential doesn't convey the fact that you're being a lazy b*gger!   s:wink: :wink: s:wink:
But thanks for correcting
Steve
Jigwar
Past: \'51 plate
mr2mark
Doesnt look like youve got a clue mate..... My advice is not to touch it.. leave it to someone who knows..... like me if you are near newcastle....
   It will cost you around £20 for a decent wiring kit for an amp .....
    then you start getting whining sounds through your speakers with the engine being so near the amp and so on ..... ==== Leave to an expert.
Whining through the speakers wasn't an issue for me on my last 2, and , like many my amp was close to the engine. Come to that , pretty much everything is near the engine on the 2.
I agree though, getting the power and earth feeds right is critical.
mr2mark
Whining all depends on the setup.... I have a big sound system i my rear bin all amped up, then another amp for the sub system in the front storage compartment.... sounds good ! also no whining   s:lol: :lol: s:lol:
Chris
/anal mode
They're more like buttons than paddles..   s:wink: :wink: s:wink:
/anal mode off
[size=100]
Ex 2003 Astral Black 6sp SMT
Ex 2002 Lagoon Blue 5sp MT
[/size]
