O2 Sensors
Started by Anonymous, March 23, 2007, 15:12
Hi Guys,
(Been scouting about forums trying to find an answer to this)
First time post (apologies if this topic has been covered before).
I took my 2003 MR2 into the garage today due to the engine management light being on. It transpires that I need a new Oxygen sensor, and I've been quoted 250 for part, labour and VAT.
The code I was given was 'P0704' - Clutch sensor malfunction
And i think the part number for the sensor is 'T89465-17201
I have a friend who's a mechanic, who suggests he can fit a universal oxygen sensor costing <50, unlike the 135quoted by Toyota.
I guess my question is... would you recommend this? Also, I believe there are 4sensors, would the universal be able to replace any?
Thanks in anticipation for any advice,
Regards
Ross
couple of further points..
from the Part number and code which identified the malfunction are you able to determine WHICH sensor needs to be changed?
My friend seems to think its one by the exhaust, although I have no idea,
cheers
enid_b
ross, welcome.
i dont see how a clutch CEL can relate to an o2 sensor.
anyhow,  there are 3 o2 sensors on the car.  2 in the manifold (the 2 wires sticking out of the exhaust) and 1 at the other end. kneel down by the exhaust pipe and you will see the other one.
they can be bought from  w www.gendan.co.uk w  or ebay do cheap generic ones for less than 20 quid.
dead easy to fit, take care not to cross thread, and there ARE HUNDREDS of posts relating to this problem.  i know because i have just read them as i changed the 3rd 02 sensor this week,
pm if u need more help
E
See you found your way here Ross....
Told you this lot will be able to help you out.
  s:) :) s:)
SimonC_Here
[shameless pimping mode on]
If it's one of the header ones, you can buy a pre wired (by mufdan) generic sensor from me Here.
It was in MufDans car for a short while and mine for a couple of runs.
My fault was with a fuse so I put the originals back in.
[shameless pimping mode off]
But I'd find out if the code was right first.
Simon
thanks a lot for your help guys
I dropped into the garage on the way home from work
Apparently its Bank 1, sensor 2 that needs replacing...
Actually, bugger it could be Bank 2, sensor 1  s:( :( s:( . Looks like im going to have to ring up, what an idiot
enid_b
bank 1 sensor 2 is the post cat, the one near the smoke end of the zorst !
IIRC.
if so make sure you get the replacement one with a long lead compared to the regular manifold ones !
E
Hugo
Just got 2 universals off E-Bay, £18 each or i did a deal 2 for £30 and changed both the engine bay sensors only to find out it was the lower one Bank 1 sensor 2   s:? :? s:?   Just off to change that one now  s:? :? s:?
2003 MR2 Lagoon blue A/C/leather [ SOLD]
2003 TVR Tamora,[373 bhp]
2006 Fiesta ST150.now sold. 2000 Ford Puma Millenium number 64 of 1000
Finally got the o2 sensor replaced (bank 1 sensor 2), I got a mate of mate to do it... hopefully it'll be ok.
With regards to the engine management light on the dashboard, would I have to take it in to Toyota for it to get reset?
Also, ive tried kneeling down by the exhaust to see this sensor, is there anythign I should be looking out for?
Regards
Ross
Quote from: "rosswilko"With regards to the engine management light on the dashboard, would I have to take it in to Toyota for it to get reset?
You could also check if anyone with a code reader is near you.
"Members with OBD II Code Readers" -topic, on top of this area.
(you can also reset most codes by disconnecting the battery for a while, but you also lose stereo settings etc.)
thanks for that, excellent idea,
I just phoned my local toyota dealer, and they wanted 32quid!
if i disconnected the battery, there wouldnt be any danger of losing use of my stereo would there? It would just reset station presets etc. One of my friends mentioned that if I didnt have original 'code' for the stereo, then I might not be able to use it?
Dont know if he's talking rubbish though
Liz
If you have the standard Headunit - double din in the car - it has no code - they must of realised that no one would want to nick it!
Thanks Liz,
Im pretty sure its the standard head unit.... the trusty WXC570R
I'll give disconnecting the battery a go then, and hope it makes the nasty light disappear for good!
Quote from: "Liz"If you have the standard Headunit - double din in the car - it has no code - they must of realised that no one would want to nick it!
s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:  Too right but many spend silly money buying on Fleabay  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:
Update:
- Got a mates 'mate' who works at a garage to fit the o2 sensor.
- Reset my battery, EML goes out.. wooo
- 20miles later, light back on.... notwooo
Any advice?
I guess the possibilities could include
- o2 sensor fitted incorrectly
- o2 sensor not producing error message
Any advice? I guess first thing for me to do is to get the code read again?
Cheers,
Ross
And so the saga continues!
Took the motor to a local garage for them to have a look at the O2 sensor I had fitted by a mates mate.
They cant see anything wrong with the fitting. Had the error message read and its still returning P0141.. (perhaps a faulty new sensor?)
Is it worth getting bank1 sensor2 changed again?
I thinking of cutting my losses and finally paying Mr T the premium to change it.
Help and Guidance MUCH appreciated,
Regards
Ross
i'd give it another go, probably just a duff sensor
Cheers Stu,
Do you recommend ebay to purchase a sensor? The garage said if I found one for them they'd fit it...
I need to make sure i get a post cat one though, with the long lead, any way to distinguish this?
Hugo
Quote from: "Hugo"Just got 2 universals off E-Bay, £18 each or i did a deal 2 for £30 and changed both the engine bay sensors only to find out it was the lower one Bank 1 sensor 2   s:? :? s:?   Just off to change that one now  s:? :? s:?
Had no problems since changing all 3 sensors, i bought them off E-Bay, where do you live? Get some to read your car again, and fit the sensor your self really easy job, it took me about 45 mins to do the 3  s:wink: :wink: s:wink:
It was read again today, and was returning p0141, which i think points to bank1 sensor2. (although the garage didnt know which was quite worrying, so i checked on here and told them, ha)
Ilive near Reading...
I dont think id be able to change the sensor myself... Ive read you need to do some wire cutting and soldering for the post cat one?
You do for any of the sensors if you buy generic, since you need to splice the old connector onto the wires of the new sensor - other than that it's an easy enough job as long as the sensor comes out OK (which, given it's only just meant to have gone in, it should!)
You're quite close to me (I'm in Slough), so if you can make it over here one weekend it wouldn't take that long to do..
What a superb offer, much appreciated. I'll try and get my hands on an O2 sensor and get in touch via PM once I do?
 m http://cgi.ebay.co.uk/BN-Universal-4-Wi ... dZViewItem m
would that suffice, or is the lead too short for post cat?
Cheers,
Ross
Hugo
That will be fine, just cut the end of the old sensor off, and splice on the new one, disconnect the wiring (which was near the near side rear light assembly on my car) and away you go  s:wink: :wink: s:wink:
fantastic, thanks for the advice
