Fitting Infinity Reference 6512si !!
Started by Draggon, May 6, 2007, 11:54
Draggon
Ok so first off, I am sorry if this is in the wrong place for this post or if it has been covered in detail already. I did a search and found some great links to remove door trim and speaker mounting template etc...very helpfull.  s:) :) s:)
but...
1. How important is Dyno mat or similar? I found this link :
  m http://www.youtube.com/watch?v=hLbxEEM433k m
Which is the Second Skin product, but not sure if dynomat will do similar thing...I was impressed by the difference, applying it made.
2. My second question is how easy is it just to cut the existing toyota speaker out of its plastic mounting and use it for the Infinitys??
I am not sure I want to cut them out incase I screw it up and end up with no sound hehe...suppose I could always buy new ones f desperate.
Anyway...any help or advice much appreciated....Just want to get rid of tinny toyota speakers  s:) :) s:)
Black 04 MR2 Roadster, Black Leather. David Style Chrome Bars (1 piece). Dev\'s keyhole covers, Dev\'s BL Visor, Small Mongo\'s with eagle stickers, J-spec nose badge, spyder rear badge, ST Crystal side indicators. TTE Springs :)
problem with the roadster is that the metal skin is thin and you do get a lot of noise through it, dynamat does work, many on here have proven that but the main issue with it is the cost, it aint cheap, but if you go to B&Q and buy roof flashing tape then the cost plummets and its exactly the same product except for the flashing tape has an ally back to it
as for the stock speaker backing, 10mins and a dremmell, been done by others before
Draggon
Thanks Stu
better go buy a dremmel then  s:) :) s:)
if they still do them, B&Q also do a 140W dremmell lookylike with a flexible snake, had mine for ages and still going strong
GSB
5 minutes, a hammer, a wood chisel, and a very rough file, will get you one pair of usable adapter units for zero cost and no need for exotic tools... Of course, if you have a dremmel, it'll make a neater job of it, but theres no need to buy one specifically.
Gorilla Ghetto Engineering  s:wink: :wink: s:wink:
Draggon
Aye...im thinking snips, file and stanley will help  s:) :) s:)
Will attempt tomorrow
