Soft Top repair
Started by uktotty, June 18, 2007, 12:12
Yes I have done a search, no I cant find anything  s:( :( s:(
Bought my 2 at the wekend, I have a 10m slit in the soft top.
Is there a repair kit you can get to fix a little hole before it becomes a big hole?
SimonC_Here
Quote from: "uktotty"Yes I have done a search, no I cant find anything  s:( :( s:(
10M eh? that's a big slit!
Someone here has repaired a small hole and there are some threads about protecting the roof from the inside by covering up part of the internal metalwork.
Replaced roof
OK quite sad searching bring this:
ROC link
With this
Fixing link
I happened to remember that there was a chisel involved.
Simon
Cheers Simon
Yeah 10M is a big slit I bought the stretch limo MR2  s:) :) s:)
Jigwar
No idea on the quality of this, but.......
Ebay Clicky
HTH
Steve
Jigwar
Past: \'51 plate
Present: \'06 plate TTET\'ed
evileye_wrx
Halfords do a soft top fixing kit which you apply from the inside to minimize the impact to the look of the roof. All fine unless, like mine, your split is along the front edge. Hence all my pics are top down!
Phil
Quote from: "Jigwar"No idea on the quality of this, but.......
Ebay Clicky
HTH
Steve
Cheers Steve
I did look at that one butit seems its just glue, no tape, no material just some sticky stuff (marine grade) to plug the hole.
Found a kit today like the on in the link so will see what happens in the rain.
Russ
If its a slit in the classic place as shown in those links, then have a look at this too. You might benefit from some preventative maintenance on the other side aswell.
Chris_h
Russ,
If accessible from the inside, and it isn't on a fold, i'd go for RIB repair patches. (as in marine rigid inflatable boat).
Failing that, the patches and glue they use to repair car tyres.
If its on a fold, it may not 'sit right' with a bulky patch.
Wow Chris thats weird mine looks just like this one posted in the other thread.
Like the idea of the RIB thing. Will let u know how I get on.
Its not weird its a very common weakness - as explained somewhere in that link I gave you. Newer hoods have had the brackets padded up to prevent (or reduce) this from happening.
Cheers Spit
Hope I have enough material to patch the other side as a preventative measure too then.
