CD Changer
Started by Anonymous, June 23, 2007, 17:09
Hi Guys and Gals, hope all is well!
I know this has been on before, however, I can not get a firm decision from any of the forums.
We've got the standard Double Din Sony Head unit and want to add a CD multi changer. Firstly are the cables already fitted by toyota or do seperate leads needing purchasing?
Are all Sony Changers compatible or not, if not, which ones are.
Liz
You will need the din and phono leads which plug into the back of the standard head unit.  AFAIK all sony changers would work with it. The excess cable tucks behind the footwell plastics, I have mine wedged behind my passenger seat.
Liz you are absolute star, so any changer will work then if I go to a Car audio shop they sould be able to sort out all the relevant leads.
DIN that is a standard connection? isn't it
So if i got a changer with leads the lead for that should be ok?
By the way nice car luv
Thanks for the help of the fault code, I'm goona get someone to look into it for me. I din't think it's much of a prob
