where to get a battery for an MR-S import
Started by Team_Dandism, August 20, 2007, 22:32
Team_Dandism
Does anyone have any hints on where to get a battery for my MR-S other than from Mr T.
Its an MR-S so has a small battery with the small posts. It's only something like 180mm wide and is even smaller than the micra one that looked feasible in the shop i went in. Its basically very small footprint but quite tall.
Thanks in advance.
Regards
Matt J..
www.team-dandism.co.uk
Got mine from a local supplier to the auto trade ... and went for something a little bigger too - there's room in the tray for it.
Just replaced that one with another - 10amps down but not as long or heavy. Terminal sizes/orientation, battery height and clamp width are all bang-on.
For reference.....
UKB code 044 for the biggie (2 year warranty), 054 for the smaller one (3 year warranty).
For anyone buying at the moment, lead is getting very expensive.  s:cry: :cry: s:cry:
halfords do them, iirc the one mentioned in the book is wrong, Aaron pointed it out a few weeks ago, but the next number up in there catalogue is correct, i.e if it say 502 then its 503 but do check the current ratings and physical terminal sizes etc etc but it looks spot on
oh and if anyone has any engineering qualifications, take proof along and get a trade card for even more money off. Airport workers can use their BAA ID passes as proof  s:wink: :wink: s:wink:
I think it's HB54 the book says, but that's a battery with tiny terminals, and the correct one is HB53..
I can't take the credit - I just remembered someone else on here saying the same thing and happened to spot it in Halfords  s:) :) s:)
that was it, i'm going to try this soon as mines flagging on startup
Silly me, I didn't check the forum before going off to Halfords to buy a new battery.  Naturally I came back with the wrong one for a UK MR2, as the Halfords book (as pointed out) says HB054 - i.e. small terminals which I gather are MRS shape.
Went back and changed it for a HB053, which has the correct terminals.  Cost an extra £13 over the HB054 - typical.
Just a word of warning though, when I went back to change it, I noticed two versions of the HB053 on the shelf!  The right one (which has the right terminals) and another one with the same terminals as the HB054 - so really it is sort of pot luck, best just to be careful when you buy.
Cheers.
Capvermell
Well mine is an official 2002 UK MR2 Roadster but they still have precisely the same very small battery as the Japanese import models.
Halfords are now charging £72.99 for the HB053.  This seems more than a little pricey to me as Tollhouse Toyota only charged about £49 for one of their MR2 Roadster batteries when the last one failed when the car was four and a half years old, four years ago.  Of course Mr T then tried to charge me 25 minutes labour for changing it which resulted in a massive complaint to head office customer services and the reduction of labour to 12 minutes.
My car is now eight and a half years old and as the car was off the road from mid July to the start of December (after needing lots of bodywork and a new clutch, oxygen sensor and having had terrible water leak problems that have amazingly only resulted in a smelly carpet but not rotted the drivers and passenger floor trays that kept filling up with water for 18 months or so) so even though I gave the battery a full charge on my battery charger before it went off to be repaired in late November and it started up OK I suppose the four months of non use have knackered it, especially bearing in mind that the battery is now 4 years old.   When I tried starting it yesterday it sounded very sluggish indeed after only 2 days of standing non driven, even though there was not the infamous click, click, click instead of the engine starting.
Well after ringing a couple of Toyota dealers I find that Motorline Toyota (formerly Toll House Toyota but now using an 0844 phone number since the change of ownership) want £62 including VAT even with my 8% older Toyota discount but Berkshire Toyota (a service only dealer) only want £43 for one including VAT (obviously this is for the battery only and you are much better off fitting it yourself at Toyota Labour rates).  So clearly these service only Toyota dealers without expensive flashy showrooms to support offer much better parts prices.
So I would say to anyone needing a new battery on their Roadster forget Halfords or Kwikfit and try Berkshire Toyota or any other service only Toyota dealer without the overheads of a big flashy dealership to support.
