REAR FOG LAMP BULB
Started by Anonymous, December 22, 2003, 09:20
I have a J-Spec 2 and so i have a rear fog in the lower grill and 2 rear driving lamps on the back (2 either side).  1 set gets brighter when you brake, the other stays normal.  I'm thinking of changing one set into fog lamps (so they will no longer be on when driving)!  I have seen how I can do the wiring which just looks to be a case of connecting the current fog lamp wire to the existing rear driving lamp and then running a loom over to the other side.
However,  the fog lamp bulbs I have seen for the 2 (in places like halfords) are a lot bigger than the normal bulb.  What is the size of it in a standard uk 2?  Is it small like the others but a higher wattage or does the cluster have room for the big bulbs?
sorry dont know but calling all people to look at this !
mph
From the UK manual:
Light Bulbs               W   Type
Headlights              60/55  A
Parking lights             5   B
Front turn signal lights  21   B
Side turn signal lights    5   B
Rear turn signal lights   21   C
Stop/tail lights         21/5  B
Back-up lights            21   B
Rear fog lights           21   B
License plate lights       5   B
Interior light             8   D
High mounted stop light    5   B
A: H4 halogen bulbs
B: Wedge base bulbs
C: Single end bulbs
D: Double end bulbs
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
