New ORC 250 light clutch
Started by spynish, November 15, 2007, 08:12
spynish
Hi guys,
My clutch is dead so I'm in the process of looking a nice alternative. I like Ogura combos but I'm scared it's too hard for me (perhaps I'm a bit gay).
I have found something that seems really interesting, the new Ogura Light series.
 m http://www.oguraclutch.co.jp/orc/orc_organic.html m
From Nengun:
The ORC light clutch series of clutches are designed for standard replacement with minimal increase in clutch pedal pressure and improved clutch feel with improved flywheel performance.
Features
- Quiet sound design - not noisy
- Custom colored clutch cover
- Lower cost overhaul possible compared to other kits
- Organic material used for clutch friction material
- Includes ORC lightweight flywheel offering 20-40% reduced weight compared to standard
Specifications
- Standard Type rated to 245NM/250PS
- High Bonding Type rated to 313NM/320PS
- Standard level pedal effort of 11-15kg/f (std 12kg/f)
So, my toughts are if Standard type will be enough since I've seen Markii is very close to that Torque capacity and I'm planning to run also 10 psi on my Hass kit as soon as I can solve my EMB problems. Standard pedal effort is superb... High Bonding is not bad either: 13~18kgf
What would yo do?
