Audio
Started by Anonymous, April 30, 2008, 10:10
Firstly id like t introduce myself to this forum, Just got my first mr2 roadster and looks the biz.
Will be using this forum regulary to gather general info and any problems i may come across
The mr2 is a 2000 roadster Jap import
My first question is the audio system in the car is still currently in Jap language, it looks like it has Tv and satnav.
Is there any way i can get this into english mode or is it a case f replacing it with my own unit.
Ive done a search but cant find anything on this
Thanks in advance for any replys
Kev
Hi Kev, welcome to the ROC.
You can put a frequency shifter in for the FM radio, although your favourite stations will be displayed under the wrong frequency.
TVs can be re-chipped in a similar way, although I haven't come across anyone who has done it on a Jap-UK car system and no idea about cost. You'll need to make sure you have a dman good aerial too  s:wink: :wink: s:wink:
As for satnav, no clue.
Not much help huh?  s:lol: :lol: s:lol:  For what its worth, the cost of conversion would probably cover a decent UK system.
Thanks very much for the quick reply.
Okay so basically im better off replacing it with a uk spec one or just installing my own head unit.
What uk spec ones are available and roughly what is the cost
Much appreciated
Kev
enid_b
welcome kev.
basically any stereo system you choose can be put in the car.
most uk stereos are whats called single din, ie it is half the width of the hole in the dash of the car.
matt sells the adaptor, which fills the hole nicely for a stereo and a little tray to store stuff in.
you will also need an ISO adaptor lead (ebay etc) very cheap to convert the wiring to match the new unit.
loads on info on here, just do a search entering audio and adaptors and you will find the answers
E
Thanks for that, il just put my own in then,
Is this the correct one on ebay
Faceplate
 m http://cgi.ebay.co.uk/facia-TOYOTA-AVEN ... 18Q2el1247 m
Iso Adapter
 m http://cgi.ebay.co.uk/Toyota-ISO-Car-St ... dZViewItem m
enid_b
the adaptor is correct, im not so sure about the face plate.
ask the seller if its a double din sized plate, which allows for a single din unit to be fitted.  the pics are never that good with these things
HTH
E
If you want to be sure you're buying the right bits, you could always order from our very own Matt:
 m http://www.autoaudioaccessories.co.uk/ m
Either via his website or shoot him a PM here (username is simply "Matt")
[edit] Oh and that fascia doesn't look like the right one, to me.
Cheers for the link aaronjb, ive just ordered both of him, at least i know both bits are going to be okay
Kev
Hi all
Received my items but the iso adapter doesnt fit the plugs thats in the car, one end fits on my radio but its the other end that are different so wont fit.
Any Ideas woyld be great
my car is a jap import year 2000 mr2 roadster 1.8vvti
Kev
Yep - you've done what I did...
Pull on the wiring that's coming out of the floor.  About 6" down from the plugs you're holding you'll find another set of plugs..
Unplug there, and plug the ISO adapter in to the resulting bit of wiring sticking up from the floor.
What plugs into the back of the stock Sony unit is actually already an adapter from Toyota->Sony  s;) ;) s;)
Hi
Thanks for the reply bud
Ive checked further down to the floor for plugs and theres none
Attached is some pics of the stereo and the plugs i have in the car at present
Kev
DannyN
That looks a lot like the connectors on the back of my stereo.
When I installed the Parrot bluetooth I had to get a lead from Halfrauds that was those connectors on one end and ISO connectors on the other.
Pretty sure it cost me less than 20 quid but they had to order it in - to make sure they didnt get the wrong one I took the actual stereo in and said "can I have the lead for this please"
Guess what?
They still got the wrong one first time   s:roll: :roll: s:roll:   2nd time was spot on and everything was plug and play from then on
Good luck
Danny
Black 51 165 BHP - Hardtop ON - Teins - Apexi Power FC - AEM Induction - Crower Cams - Forged Pistons - Iridium Plugs - Zero Manifold - SP Downpipe - H&S - TRD SS - Corkys MSMB - Goodridge - '03 Vents - Devs - Bamas - Crystal Indies - Mongos
OK now you have the ISO cable you need ISO to (Head Unit)
replace (head unit) with JVC, Kenwood, Pioneer Etc.
So you have got a cable to convert Toyota to standard, now you need one to go standard to Head Unit.
Simple
[Mod]Kevhky, can you please reduce your avatar to the specified size. Thanks. [/Mod]
Hi
The picture of the radio is the jap radio that came in the car (not my new sony hu which i want to instal) when i got it, i was just showing  it so you could see the connections
The iso cable i got fits perfectly into my sony hu but the other ends will not fit the toyota wiring and if it makes any difference my car is the mr2s year 2000
Sorry if i confused you
Help would be appreciated
Kev
The correct harness does exist out there for the MR-S Kev. I'm not aware that the wiring differs between UK and import so it sounds as though you've been given the wrong one.
Unfortunately I lobbed the packaging from my autoleads harness years ago so can't help you with a part number.  s:oops: :oops: s:oops:
yep neither the head unit nor teh car wiring are ISO standard
so unless you get lucky and get a Toyuota to you new head unit converter
what you need is 2 things
1. Car to ISO lead
2. ISO to Head unit lead
when I did this with my kenwood teh resuling mess was so big I couldn;t get it under teh carpet and ended up building my own
Sorted
Firstly went to Halfords - they wouldnt order one incase it wouldnt fit so told me to go to the Toyota Dealer
Toyota Dealer said they dont supply any leads leads other than the standard iso connector
Went home sick as a chip with no lead
Thought when i got home id have another look for the correct connector and Bingo there it was tucked round the side under the carpet.
Radio now working spot on
Thanks to everyone on here for their help on this much needed forum
Kev
Quote from: "kevhky"......Thought when i got home id have another look for the correct connector and Bingo there it was tucked round the side under the carpet......
Glad you're all sorted. Sorry I've only just seen this thread. Any probs with audio related things, just shoot me a PM.
Cheers, Matt.
AVH-P4000DVD  In-Dash Double-DIN
dear all, I have put this pioneer in.......looks amazing with the top down!
