LHD Lights on RHD Car?
Started by uktotty, June 24, 2008, 00:16
Can you buy a set of USA Headlights for LHD and fit them to a RHD? How do you change the beam angle?
Can it be done?
SteveJ
Quote from: "uktotty"Can you buy a set of USA Headlights for LHD and fit them to a RHD? How do you change the beam angle?
Can it be done?
Very simple answer - NO!
The deflectors (and hence beam pattern) are completely different shapes - it's not just about angles.
Cheers Steve, and this would be an MOT failure as well as being dangerous?
Quote from: "SteveJ"Very simple answer - NO!
I think you meant no to the second half of that question, right Steve?
UK Toyota has a part number (for RHD cars) for continental beam-pattern lights.  They're recorded as "RHD, Right-Hand traffic" as opposed to "RHD" and the part numbers are identical to standard European part numbers for LHD Roadsters.
Thus, Toyota should have no problem ordering a set of left-hooker lights in the UK.
Cheers Aaron, it was just me being tight, I found a set of 04 LHD lights cheap and wanted to do a bodge job  s:( :( s:(
