EBC brake discs?
Started by ChrisGB, July 29, 2008, 20:00
ChrisGB
Hi to All
Am about to replace brake discs on all 4 corners. The stock Toyota fronts have corroded again, so it is time to try something else. I am looking at fitting the EBC discs (plain not grooved) al round. Anyone used their discs?
Pads wise, I am probably going for Mintex Extreme as I am very impressed by them on another car I have. Am open to suggestions on alternatives though.
All input greatly appreciated.
Used their discs in the past, and they were rubbish.
I have them on the '2 now, and the discs are fine (just avoid the Greenstuff pads, which are terrible)
ChrisHumes
i have the grooved discs and greenstuff pads. discs are good, not corroded at all and look the business.
Ive had them on probably 10k miles now, but i have noticed that they squeal alot now, this could be down to the pads being worn out as it sounds like metal on metal(?) or normal, aaron - any views on this and what brake pads to get for best results?? (sorry to go off topic!)
Hmm mine don't squeal, but they've only been on a few thousand miles.  If it was metal on metal you'd know about it (by the lack of stopping power!), but it could well be the wear indicators hitting the disc telling you they need changing.
They do seem extremely soft.
As for replacements, I can't decide if I want to chance it on RedStuff, Mintex or see if there are Porterfield pads available for our cars  s:? :? s:?   I'd really like something not-too-dusty though (with the white wheels  s:shock: :shock: s:shock:  ).  I wonder if Axxis make any metallic pads for our cars - I should check.
[edit] Ooh, the Axxis Ultimate (ceramic) pad is available for our cars, and they're meant to be low-dust.  I can't find any online reviews of them, unfortunately (the MetalMaster pads were highly rated in the 300ZX world, though)
I'd go along with half of what's said above. The discs are great and mine have survived a couple of salty winters now. I've got no issue with the Greenstuff pads at all, but considering my original stockers lasted 95000 miles i guess I don't brake as heavily as some.  s:lol: :lol: s:lol:
I've heard the Redstuff pads are dire until they're hot.
I like my slotted / dimpled discs.
They are a bit noisy at times, but not making scraping noises.
Being different (as usual) i have the blackstuff pads and have no problem with them at all - seem to be lasting well too.
Comparing to the dust on Ste's wheels there's really little difference that i've noticed in the production of dust.
ChrisGB
So the discs are generally regarded as being OK. Pads wise, I run Mintex Extremes on the Fabia. It is mapped and capable of some pretty punishing demands on its brakes. The Mintex ones were OK on even the most arduous one hour very fast B/C road blast across country. The pads are OK on normal driving, but once you get some proper heat in them they just get better and feel is excellent, so I am trying them. Just hope the EBC discs are better than the Brembo items I have on the Fabia. The drive which the pads thrived on warped the discs!
Chris
I've just put some EBC discs and greenstuff pads on the front of mine, after a disc advisory on the MOT.
About 2 minutes after I pressed the Paypal button I saw Mark's "don't buy them at any price" post   s:( :( s:(  . However I was going on Ste's " I've never had any problems " offering   s:D :D s:D
Just to say, after only a few miles they are definitely better than what was on there before - though maybe the fluid bleed had something to do with that.  Anyway, we'll wait and see. Generally I think my driving style is "a la spit", but Anglesey might put the cat amongst the pigeons.
Just to say i think the discs look good   s:wink: :wink: s:wink:  at the mo.
I've got the EBC slotted and dimpled disc plus green stuff pads fitted all round, so far OK the dust is a bit of a pain - it gets my wheels dirty  s:D :D s:D    s:crazyeyes: :crazyeyes: s:crazyeyes:
Also I do get a ringing noise from them when I push it hard, but I think that's the nature of the slots and dimples.
Rob.
ChrisGB
Quote from: "roger"About 2 minutes after I pressed the Paypal button I saw Mark's "don't buy them at any price" post   s:( :( s:(  . However I was going on Ste's " I've never had any problems " offering   s:D :D s:D
Hi Roger
I am having difficulty finding that particular thread. Was it the discs or pads (or both) that Mark was not keen on?
Chris
Here we are, Chris. It was the discs.
ChrisGB
Well found out today that Mintex no longer make the Xtreme range of pads, which is a shame.
So we now have choices:
Mintex M1144
EBC Greenstuff
Pagid Fast Road or RS 4-2-1
Ferodo DS Series
Any other suggestions or comments on the above greatly appreciated. Given that my car is not driven daily and suffers disc corrosion, an abrasive pad compound is desirable.
Chris
I'd avoid greenstuff like teh plague
I have 1144s on teh VX and like them
Pagids have a good rep too
however on teh roadster I really couldn't fault teh oem pads, even on upgraded disks they were more than fabulous on road or track
See, I had the 1144s for a while and hated them , but loved the Pagid RS14 (not teh squealing they made, though).
I do agree with Mark though, for value + stopping power + fade resistance then the stock pads really can't be beat IMHO. Failing that, I might be tempted to try the Yellowstuff if they do them, or see if Performance Friction make a pad for the MR2 (I'm using them on the Zed right now, and OH MY GOD do they stop you when you really lean on them, albeit at the slight expense of feel).
ChrisGB
Thanks for the input guys.
Looks like EBC discs and stock pads for now. Never had any problems with stock pads, good feel and progression, no fade.
Chris
carl_evs
Quite a few people seem to dislike the Greenstuff pads but I haven't had any issues with the ones that are fitted to my 2!! I actually quite like them - they came with the discs i bought but i wouldnt be against getting another set.  Anyone else got them fitted and like them??!
2nd Place - Northern Treasure Hunt
\'52 Lagoon Blue SMT - Likwidart graphics - quite a bit of other stuff...most homemade!!
Quote from: \"nelix\"Sold him my knob, fast payment, thanks
ChrisHumes
i have and think there quite good, but when i changed from stock i though the stock were better, maybe it was just them bedding in?
Ive got an mot next week and if I need new pads i think i will try the stock again so will let you know.
ChrisGB
Well I have the stock pads and the EBC discs are ordered. Discs cost £117.85 including delivery from Braking.co.uk  Pads around £65 from Mr T. Fitting Tuesday night if all goes to plan.
I am hoping that the EBC discs resist the rear surface corrosion better than the stock ones did. Still not sure if it would be wise to put some extra ventilation in the heatshield plates. Are they screwed on? If so, perhaps there is room to fit spacers to take them further away from the disc to aid drying.
Chris
I wished they were just screwed on, they are clamped between the bearing housing and stub axle housing so you have to remove the bearing assemble to get it off - big job. I was going to get them powder coated then decided not too, so I think I will wait until the bearing fails.
Rob
ChrisGB
Quote from: "FGRob"I wished they were just screwed on, they are clamped between the bearing housing and stub axle housing so you have to remove the bearing assemble to get it off - big job. I was going to get them powder coated then decided not too, so I think I will wait until the bearing fails.
Rob
Hmmm wonderful. May just take a drill to them, or alternatively, just see how the EBC discs cope.
Chris
just noticed this post. i see that no one mentions black diamond disks and predator pads. i have read good things about these. has anyone had any experience with them?
Me and Mark ran BD discs on our old MR2s with the stock pads, and that's where we got the best results from.
I use the BD pads and they work very nicely. Dust is also kept to a minimum as well which is nice.  s:) :) s:)
ChrisGB
Quote from: "Ekona"Me and Mark ran BD discs on our old MR2s with the stock pads, and that's where we got the best results from.
Funny that the stock pads are so good really. They area after all for Yaris variants as well (the fronts at least). I was seriously looking at all sorts of performance alternatives. The EBC Greensutff were cheaper than stock pads, the Mintex 1144 quite a lot more expensive. However, as the stockers have never let me down, or even hinted at fading on the most arduous of fast B road drives (the environment that is probably hardest on brakes due to lots of hard acceleration and braking but speeds often too low to get a decent amount of air over the discs for any decent amount of time), so I thought I would go for them again.
The big thing for me is the corrosion of the front discs. I am hoping that the EBC discs, being soft by some accounts, will either be reasonably corrosion resistant, or will clean up easily due to their softness. Hopefully will have them all fitted on Tuesday night.
Chris
I'm another with BD discs and stock pads  s:wink: :wink: s:wink:
