Seatbelt Light
Started by Ama_1979, August 28, 2008, 09:14
Ama_1979
I noticed this morning that the passenger seatbelt light was flashing although I had no passenger.  I have not noticed this before when I don't have a passenger – is that supposed to happen?  Does it sound like I have a fault?
Thanks in advance
  s:wink: :wink: s:wink:
Mine always goes off when I have my laptop in the passengers seat, do you have a very big make up bag???
Ama_1979
LOL nooooooo.....
So you think it's nothing to worry about then Mr?
Well if the seat is empty then you have a fault, if there is something on the seat then nothing to worry about
NorthandSouth
Mine goes off sometimes when I drop my handbag on the seat. Once I move it, it goes off again    s:D :D s:D
Lynne
2004 Sable Red Edition now sold :( and would so love another!
Ama_1979
Ahhhh yes I did have a couple of things on the seat, fairly heavy too..
That will explain it then...ooo that's good then. Sorted.
Thanks for your replies
  s:D :D s:D
reach under the seat and disconnect the plug, problem solved
Stop putting your handbag on the seat or take out 90% of the stuff you don't actually need in there, problem solved!
oh and if anyone thinks that disconnecting it may effect the airbag operation, then disconnecting it has the same effect as sitting in the seat with the seatbelt on, something which has never been directly confirmed anyway
