Audio wire diagrame
Started by Anonymous, November 2, 2008, 18:11
Hiya i am having problem again. was going to fit myself a DVD player in but after took out the old stero out find out its a mess inside all the wire and cable be change.
wonder has anyone got a wire diagrame or and anyone knows the colour of the cables?
mine is 2001 model
Thank you very much   s:bowdown: :bowdown: s:bowdown:    s:bowdown: :bowdown: s:bowdown:
You probably need This, clicky.
Quote from: "nelix"You probably need This, clicky.
i know iso would help, but the problem for me at the moment is all the wire is be cut by the last owner and only can say its a mess there has no more adapter anymore. just cable hard around. >.<
cclarke99
Colours should be
Blue/yellow    Power (on all the time)
Grey             Power  (from ignition switch)
Black            Up/down signal to aerial
Violet           LH speaker -
Pink             LH speaker +
Light green  RH speaker +
Blue             RH speaker -
Brown          Ground
Quote from: "cclarke99"Colours should be
Violet           LH speaker -
Pink             LH speaker +
Blue             RH speaker -
Brown          Ground
thank you very much
just get it sorted.
many thx
