Turbo oil return fittings
Started by SimonC_Here, April 28, 2009, 12:04
SimonC_Here
Now I've got a new oil pan with a welded oil return fitting, I just need to replace the actual oil return line.
The current one is a bit tatty and has a push fit connector with a jubilee clip holding it on to the oil pan.
Now my new return has a thread so I'm guessing I need something like This I just can't remember what the bit that attaches to the turbo looks like on mine.
I have a thought that it's some kind of banjo bolt at the turbo end or is that the coolant line?
pop to pirtek and they will make you up one to exact spec for peanuts
scottish_turbo
Quote from: "markiii"pop to pirtek and they will make you up one to exact spec for peanuts
Thats exactly what I did. It was definately worth doing as it made a big difference as I was constantly having problems with my oil return line.
SimonC_Here
Oh, just down the road.
NickNJ
do you need to fit a new oil pan when fitting the turbo?
Black MR2 Roadster
philster_d
Not a new pan, but you will have extra oil lines for the turbo. So it needs a place to return to the system.
HTH
Phil
SimonC_Here
I've got 3 now!
The one in the car leaks a bit. I've got a stock one and a modified 2zz one which I'm going to fit when I've got the oil return pipe.
Quote from: "NickNJ"do you need to fit a new oil pan when fitting the turbo?
no but we will need to remove the old one and drill/tap it
unless of course your kit comes with one
NickNJ
I'll cross the bridge when I get to it then  s:) :) s:)
Black MR2 Roadster
