Slow Warm Up
Started by Anonymous, February 9, 2004, 19:22
How long does it take for engine to come up to temp.  I have to drive for at least 3 miles  s:?: :?: s:?:   My other car (the Focus  s:roll: :roll: s:roll:  ) is up to temp in less than half a mile.
I often get 10 miles before it's up to temp.
do you mean water temp or oil temp? Remember the dial on the dash is water, which will take longer on colder days...
MRMike
I take it your talking about water temp and not oil temp?  I thought the Oil took up to 10 miles
Then.. Blue 350Z
NOW M3 V8
If you're talking about the temperature dial (water), it takes between 5-10 minutes on my car.
I used to run a 306 which also warmed up much quicker than the MR2, I believe this is because in a front engined car the radiator is close to the engine, so not only do you have less coolant in hoses, but the engine bay is much hotter and radiator is also warmed by radiated heat from the engine (esp manifolds) which gets you up to temp quicker than a rear engined car with a stone cold radiator that isn't getting any external heat.
As for oil/water temp, oil temp typically takes twice as long to come up as water (obvious if you have a car with both oil and water temp gauges).
