alarm keeps on going off after a flat battery
Started by Anonymous, July 6, 2009, 13:18
my roadster "2003" had a flat battery.
charged the battery back up.
i can start the car. lock, unlock the car with the remote key.
but the alarm goes off all the time.
any ideas please?
cheers JON
Hi Joni. Sorry your first post is a problem, but lets hope you hang around.
My first comment would be are you sure the battery is holding a full charge? Alarms are known to operate when they are low.
And secondly, is the red alarm activation light still flashing when you have unlocked?
I am assuming of course, before the flat battery problem everything was tickety boo.
yea everything was ok till the flat battery.
i even disconnected the battery, charged it up over night on a trickle charge.  in the morning the battery wasnt taking any amps.
connected it back up and the alarm went off.
the red alarm activation light is still flashing even when the car is unlocked. and the hazard lights are going.
pulling my hair out.   just from a flat battery.
toyota say they want over £100 just to look at it.
muffdan
can you try another battery?
Quote from: "JoniTheOx"the red alarm activation light is still flashing even when the car is unlocked. and the hazard lights are going.
That sounds as though you might not have not inactivated your alarm - or your battery in your key needs replacing. Try locking / unlocking using the key rather than the buttons.
tried another battery and used the key to unlock the car.    and still thealarm Led is flashing.
cheers for your help tho.
im scratching my head big time.  all this problem over a flat battery.
Are all doors,bonnet and engine cover shut when you activate/deactivate alarm?
wbarrwebster
What about attempting to re programme the remote, surely got to be worth a try.
B
W. B. Webster
