Turbo spark plugs, what do you use? and is Imp/uk maf same?
Started by Ilogik, July 10, 2009, 15:43
Ilogik
Guessing now I have a turbo would be better to go for a colder grade spark plug?
and finally does the UK and import maf sensor differ or all the same, and can anyone recommend where to buy them? looked at Camskill they are £120.
Ex: TRD stage 1 TTE Turbo
muffdan
cheaptoyotaparts for the MAF, import and UK spec are the same.
I use NGK Iridium plugs from MWR
Ilogik
Quote from: "muffdan"cheaptoyotaparts for the MAF, import and UK spec are the same.
Wicked is there different ones, or just one set iridium one bud?
don;t bother with iridiums just changethem mor eoften
I've used NGK copper BKR6EY11 on all teh 9 turbos I've installed with no issues
make sure they are in before you get it mapped
muffdan
Iridium lasts longer but the quality of the spark isn't as good as that produced by copper. I had NGK Iridium plugs on the SP350 setup and noticed no problems with them so thought I might as well stick with them and $9 each is damn cheap!
Quote from: "markiii"I've used NGK copper BKR6EY11 on all the 9 turbos I've installed with no issues
Not sure if one of them was mine - but I've had no trouble (bought them from Halfords as well!!)
Quote from: "roger"
yep, if you'd had iridiums they would have been £70+ and you would remember
custardavenger
Got my iriduims from opie, was a good deal. £35 ish i think
Project Custard Clicky
Quote from: "muffdan"Iridium lasts longer but the quality of the spark isn't as good as that produced by copper.
There are iridiums and then there are iridiums. Most of the iridiums are actually "economy" plugs, which last forever, but aren't really that good. Then there are "power" plugs, which don't last that long, but are better when it comes to the spark.
If you can find BKR6E without the suffix, then they're already pre-gapped to 0.9 mm , so they go straight in.
If you opt for the Y11 then you're buying plugs gapped at 1.1mm.
y11 also have a longer nose from memory
Aren't you normally advised to have copper plugs in when mapping is done, in case of knock damaging the electrode and sending particles into the engine?
Hadn't heard that Nige
Oh, and big nose - yarp!
i put 4 BKR6E plugs in about 4 hours ago, they were (as Ste said) gapped to 0.9mm (now 0.8mm) £7.50 delivered for the whole set.
I'll let you know how they are once i get everything else finished off tomorrow as most of this evening was spent getting the rust bucket of a manifold and cat off the car!
