Wireing a multi cd player
Started by alancdavis, July 14, 2009, 21:22
alancdavis
Just gor a OEM sony multi player from one of our members   Where can I get a connection / fitting instruction ?
Red Calipers with DBA Cross Drilled and Grooved Discs,,,,2005 Red and Black Leather Custom Seats,,,,,TSW,17ins Wheels,,,,,2003 colour coded side vents and rear bumoer inserts,,,,Custom rear bumper skirt,,,TTE Twin Rear Pipes,,,,,,TTE Front Bumper,,,,,Red and Black Steering Wheel,,,,,Blitz Induction Kit,,,,,TTE Style Bar,,,,,Goodridge Stainless Braided Hoses,,,,,,,,,Front and Rear Strut Braces,,,,,,Rear spoiler
it needs 3 wires dual rca and a control cable
enid_b
what is it replacing alan? stock or aftermarket hu. im just thinking wiring to myself. tell me more and i will too
wbarrwebster
Hi,
I assume it's going into the Sony head Unit!
Just run the wires from the back of the HU. Just make sure the red and the white go in the correct holes....(it won't blow up if you get it wrong..)
Run the wires  behind the carpet..take out door cill, run the wire under ....into the bottopm of the bin ( Assuming that's where you're gonna fit the CD unit ) Loose some of the wires at the passenger footwell as you won't need ithem all and you don't want all the excess wire in the bin!
Think about getting a remote commander ( it connects to the blue circled aperture at the back of the HU, sits to the left of your steering wheel cowl) makes  altering stations, cds, volume etc, that much easier.....don't buy new, pick it up on Ebay .Remember get the right one, they are not all compatable..
B
W. B. Webster
alancdavis
Quote from: "enid_b"what is it replacing alan? stock or aftermarket hu. Im just thinking wiring to myself. tell me more and i will too
Just adding it to stock sony unit
Quote from: "markiii"it needs 3 wires dual rca and a control cable
alancdavis
Quote from: "wbarrwebster"Hi,
B
Cheers   I will be fitting it when I install my new center console ( if I evver get the wrinklr paint finish sorted)   so wired can run under that
