nothing
Started by toyotasi, August 20, 2009, 13:22
toyotasi
deleted
SimonC_Here
Dodgy battery?
If the battery isn't up to it then it will draw power from the alternator and/or dip the lights.
Mine does this ever so slightly - always has.
As long as it doesn't stall!   s:lol: :lol: s:lol:
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
wbarrwebster
Quote from: "Wabbitkilla"Mine does this ever so slightly - always has.
+I.
If these are no other symptoms, she should be ok.
Keep in mind that modern batteries  die very quickly unlike yesteryear, where they would stagger on for weeks before they gave up the actual ghost!!
B
W. B. Webster
With the windows that is normal - there is no safety cut-out on our windows, so by telling the motor to raise the window even though it's already on it's stops you create a massive current draw (because the motor is stalled), which dims the lights at idle as the alternator can't keep up.
Electrical motors really do not like stalling - if you've ever stalled a power drill you'll know that  s;) ;) s;)
toyotasi
Thanks for all your replies, nothing too serious too worry about   s:bowdown: :bowdown: s:bowdown:  just something to keep an eye on  s:crazyeyes: :crazyeyes: s:crazyeyes:
Quote from: "shuttsies"my air con (not working at the moment) but when i press the button... my revs increas by about 400/500.
Increase in revs (possibly not by 500 though!) is normal when you turn the air con on, only at idle though.
normanh
Just a simple thought check that your battery connections are clean and that you have a good earth.
normanh
kentsmudger
Quote from: "shuttsies"....my air con (not working at the moment) but when i press the button... my revs increas by about 400/500.
Its basicly an electrical turbo   s:twisted: :twisted: s:twisted:
  s:?: :?: s:?:    s:?: :?: s:?:    s:?: :?: s:?:
The revs rise a little to cope with the power drain - You are not getting any more power
Quote from: "kentsmudger"
I 'think' he was joking  s:P :P s:P
Thudd
Hmmm rig up that electric turbo and fit an intercooler next to the aircon condenser. It's like a perpetual energy machine!
