Aerial isn't going up and down?
Started by Anonymous, September 22, 2009, 20:50
Hey, ive been having problems with my aerial since i bought the car. Its been staying up all the while with and without the stereo on. The stereo is standard sony. I didnt realise it was meant to move until a mate said there should be a motor in that! lol So can anyone give me any idea's in how to get this lil thing to start moving again please? Many thanks  :-) :-) :-)
Does the motor make a noise near the aerial when you turn the radio on?
No, there's been nothing, no movement, no noise....not even a squeak! lol
It could really be anything, from not being plugged into the radio, through all the electrics, fuses etc, to the shaft itself. Unfortunately I'm not sure if there is a quick fix.
Check the easy stuff like fuses first and maybe the connection to the back of the stereo as if you use a torch you can see these.
Quote from: "life of bryan"Check the easy stuff like fuses first and maybe the connection to the back of the stereo as if you use a torch you can see these.
also you can check to see if you have got a live going into the control box for the aerial. this is located underneath the bin behind the drivers seat.
richard
