Check Engine Codes
Started by DAZ400, February 20, 2004, 16:58
DAZ400
How do you get the check engine codes ?
I have heard you connect 2 pins together on the OBD2 connector and then count the flashes of the light is this correct ?
Which pins connect together ?
Has anyone tried connecting a laptop to the OBD2 connector and know what interface it has ?
IE I2C, 485, 232, CAN etc....
So many questions.........   s:D :D s:D
SOLD No more 2. Just a bus for the family..........
SteveJ
Pocketlogger software running on a Palm, with the pocketlogger OBD-II > Serial converter
markiii has one, and mph is contemplating getting one too
Jap GT300
They dont work on J-Spec cars!
have a look here daz  m http://www.obdii.com/ m
loads of info.
Thread revival!
If I can get a CEL code how can I find out what it means? Is there a list of codes/descriptions somewhere?
GSB
Many codes conform to the OBDII standard, so you can find out that way, or you can invest in a set of workshop manuals which detail not only what the code means, but which engine components to investigate in order of liklihood of them causing the fault.
I bought a box of tricks for my laptop that downloads the codes, tells you what they mean, and resets the CEL as well...
 m http://www.mr2roc.org/forum/viewtopic.php?t=4171 m
mph
Quote from: "jag"If I can get a CEL code how can I find out what it means? Is there a list of codes/descriptions somewhere?
Yep, right here!  m http://www.mr2roc.org/content/articles/OBD2/obd2.php m
Print friend (A4 landscape) version:  m http://www.mr2roc.org/content/articles/ ... rinter.htm m
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Cheers guys   s:D :D s:D
