Super Taikyu lowering spring kit
Started by diddy, December 1, 2009, 13:51
diddy
Any good guys any differene between tte and these?
andywood
No idea on those, but what is your perceived advantage of them over the TTE springs?
The TTE springs are a pretty good price and are relatively fit and forget in terms of being used with the stock dampers, not sure why anything else would need considering unless you want to go even lower than the TTE in which case you will need new dampers as well or coilovers.
Andy.
diddy
only reason is they are £40 cheaper than tte.
andywood
Your choice i suppose, but for the sake of 40notes i would go for the proven tte springs that many people run with no problems to vehicle or to handling.
Not much info around on the Taikyu's so really depends if the tte's suit your requirements.
tte's will give you better/lower ride height, tighter handling but very little degradation in ride quality/crashiness.
As Cilla used to say, the choice is yours   s:wink: :wink: s:wink:
Andy
