Driving the water guage
Started by muffdan, December 17, 2009, 15:15
muffdan
So does anyone know anything about how the water guage works? What does the ECU send it to make the needle go up and down?! I need to drive it myself so I have to figure out what it wants in terms of signal to work.
SteveJ
There is no feed to the instrument module from the temperature sensor, so it must be being controlled over the CAN-bus
muffdan
cheers Steve, do you know what CAN protocol the ECU uses? Basically is it standard or a Toyota proprietry version?
SteveJ
Try this as a starting point - http://www.vassfamily.net/ToyotaPrius/CAN/cindex.html#OC.
It's for a Prius, but I suspect a lot of the data stuff is going to be relavent - I can't see Toyota re-inventing it all from the ground up for the '2
muffdan
awesome, that's pretty much all the information I'm going to need. Brilliant, cheers Steve.
I never could understand why certain gauges and things disappeared into a box on the wiring diagram, I assume that's why.
