Need info before installing new system
Started by Anonymous, February 28, 2004, 17:18
I have a 2003 US spec SMT and want to replace the stock system but before I start I was wondering about hardware for the installation. I am putting in a Kennwood HU (KDC-3027A), Focal Componets( 165 V Slim) and a Blaupunk amp (GTA 250). I spent some time reading the other threads but I can't figure out what else I should get to get a nice clean install and prevent me from running back and forth buying unexpected parts as I do the installation. Any one have any suggested parts such as the wiring harness, mounting brackets, ect? this newbie thanks you
The only parts you will need are speaker brackets (make your own or use the plastic Mr T 1's)
A Toyota loom for the kenwood headunit
wires 12 aug about 4 -6 meters and a soldering iron or crimpers
If your instakling the amp make sure you buy an amp kit with fuse hodler and earthing straps etc
