JVC Stereo
Started by jjr197, March 30, 2010, 13:33
jjr197
Hey guys. Have any of you got/used this JVC stereo on your 2s?
Looks decent value for money for what it does in a Dbl Din.
http://www.caraudiodirect.co.uk/jvc-kw-xr611.html?cadid=c0k23vm94ervr1dmhffqch5515
Jimi
"If you're driving with the top up, the storm outside had better have a name!"
sonixtorm
Maybe not a great deal of help, but if you are in the market for Bluetooth handsfree and similar features as the JVC, I went for one of these (@£240):
 m http://www.pioneer.co.uk/uk/products/25 ... index.html m
It works really well with the iPhone for both iPod control (with the exception that you have to click "no" when it says it's not designed to work with iPhone) and handsfree phone.
chuckie
Have installed one of these, not got bluetooth working yet thought, fits well with the facelift surround
 m http://www.incarexpress.co.uk/view_prod ... tno=CX609E m
Ch
Now long gone, MR2, 06 Silver, AC, Black/Grey Leather/Alcantara Seats, Grey Alcantara Door Cards, Hard top.
Replaced with, BMW M240 Coupe, Estoril Blue(and 340bhp).
Partner has, MR2 06 Blue, Hard top.
redcarblackhorse
Am in the process of fitting this JVC stereo. I have a 1999 import and it is not the same size as the original stereo. a little modifcation is needed to the old stereo surround to tidy up the gaps.
1999 MR-S with a few tweaks!
Circuit de catalunya
24 Heures du Mans
Thruxton
Abingdon Track day
Don of Croy
Hi chaps - I'm looking at these 'bargain' JVC's at the mo...
...how did you get on? Good piece of kit? Any issues with final fit etc.
All help appreciated.
MR2 Roadster Lagoon Blue + SMT + Hard Top + Air Con
Volvo V70 D5 SE with loads of extras...
Honda Jazz - first choice for town use when we can\'t fit in the \'flip flop\' (MR2)
stargazer30
Hi
I have this JVC unit in my MR2, same as the link but mine has integrated BT handsfree.  Its a good unit for the price, handsfree works well, the variable colour display lets you match it to the 2's interior dash colour.  It has 3 x pre outs.  The best bit for me is the pro EQ though.  It allows you to shape the sound very accurately to match your taste and speakers.
The only bug I found on mine is the USB audio, very occasionally you have to turn the HU off and back on to get it to read from the USD.  Its caused by the initialisation being interupted by starting the engine I think.
Fitting them is a doddle, straight swap pretty much you just need a wiring adaptor.
David
Don of Croy
Cheers David!
Don of Croy
Oops - pressed submit twice (too quickly).
I have the JVC 811 one in mine with the inbuilt bluetooth car kit, and for the price it is great value. can play music from the iphone with full ipod control via the lead, but also in a imited way over bluetooth. the car phone kit part is fairly ok given the type of car its in. the system seems to pack a fair bit of punch and good to have the sperate sub out and you can control level and low and high pass filters all from the set. Let alone all the hundered of different colour options for the display  s:) :) s:)  the only issue i have and not sure if it is how it was fitted is that the electric aerial comes up all the time when switched on when the old sony set was just up for radio !
stargazer30
Quote from: "lccsw"the only issue i have and not sure if it is how it was fitted is that the electric aerial comes up all the time when switched on when the old sony set was just up for radio !
This is common for aftermarket HUs and a very easy fix, most people (me included) wire the rather useless window lockout switch to the power antenna wire (blue I think)  on the back of the head unit.  That way the ariel only comes up when you press this swtich (and the HU is on)
ah that makes sense might have a look over the weekend - many thanks
Don of Croy
Now fitted!
Have to make some side 'flashing' as the new HU is approx. 1cm thinner, but acceptable for now.
Bought a cheapie wiring harness £9.99, couldn't get it to work at all, visited Halfords and very helpful chap had a fiddle and hey presto! There are still two plugs over from the back of the original radio - wonder what they did?
Seems to be louder than the old radio, more depth, works the iPod a treat, hands free telephone calls also...so far so good. Worth it for £168.00.
Many thanks for your help and advice. (And the aerial is behaving too).
stargazer30
Quote from: "Don of Croy"Now fitted!
The two spare plugs are not needed, so your fine there.
The edges I used small square PVC trunking from B&Q as it has a self adhesive backing.  Its white so I covered it in black insulation tape and stuck it on the inside sides of the stock surround.  Sounds like a bodge but it looks decent, you can't tell its a DIY fix.
