PO141 Resistor Guide?
Started by uktotty, April 11, 2010, 11:12
Did anyone do a how to for this one?
don't think so its too simple to need one
nathanMR2
Nice one, cheers Nath, and Markiii
ChrisGB
I found 34 Ohm to work perfectly. Look for a 10 watt dissipation one as it is going to get hot.
Chris
Russ,
Not something we've added to the ROCshop, but we're holding a stock of 27ohm wirewound resistors donated by Nic that'll sort you out in exchange for a small wedge to ROC funds.
I'll prep these with some tails to make installation easier. Drop me a PM if you're interested.
Cheers Ste
Might get George to contact you then mate, I bought mine from maplins but it was 40ohm IIRC
Russ
That may well be OK Russ.
A number of us here are running 15ohm with no issues at all but the Spyderchat guys favoured a higher resistance which is why our current batch is upped. I lost track of their thread so I can't confirm whether they established an upper limit that the ECU is cool with. If you try it out, let us know   s8) 8) s8)
