MRS alarm/imboliser, how to start the car
Started by redcarblackhorse, April 25, 2010, 17:35
redcarblackhorse
Hi. I am a newbie to the MRS. I have just bought one and understand that being an import I need to have my foot on the clutch to stary it. i am confused with the alaram system. The key remote will lock the doors but not activate the alarm. If i activate the alarm with the alarm fob, it will beep for about 15 secs then the alarm will sound. So it seems i can not just acrivate the alarm and leave it. Also to start the car i need to activate the alarm/lock the car, then quickly deactivate it (as it beeps), then put my foot on the clutch, and then i can start it. If i do not go through the cycle of araming then disarming the alarm I can not start the car. Is this normal? Any help please.
1999 MR-S with a few tweaks!
Circuit de catalunya
24 Heures du Mans
Thruxton
Abingdon Track day
Ilogik
Didn't think the MR-S came with a factory alarm or immobiliser from what I remember..
Ex: TRD stage 1 TTE Turbo
Peter Wright
Aftermarket alarm only for insurance only in the UK
You will have to go to an alarm company or disable it somehow
SimonC_Here
So it will be an aftermarket, now you've just got to find out which one and then find the manual!
redcarblackhorse
ok thanks all. I think it is called sigma. A searching i will go  s:D :D s:D
24 Heures du Mans
Thruxton
Abingdon Track day
philster_d
I think I had a sigma meta alarm in my mark 2. i dont think it helps you any way. I would say make sure everything is properly closed, the engine lid and the frunk. that is the sort of thing that upsets the alarm.
phil
if it is beeping then you have a sensor triggering it.
Probably the boot, bend the sensor up so it makes contact, see if that stops the beeps.
Then try the bonnet and see if that works.
Mine did this and I fixed it
redcarblackhorse
Yes you are right, it was the engine switch. Have replaced it and all is good. Thanks
24 Heures du Mans
Thruxton
Abingdon Track day
