SONY stereo not working
Started by Anonymous, June 15, 2010, 11:08
Hi,
I have just removed my sony stock stereo from my mr2 to look at how its fitted to the double din holder and then reconnected it exactly as it was before but now the stereo will not work ???
It just displays the time and thats it!
any ideas as this will drive me potty?
Cheers james
StuM
There is a tiny reset button (from memory) just above the volume dial - need a paperclip end or something to push it.  Might be worth a go..
Stu M
tried that and still nothing   s:? :? s:?
thanks for reply thou mate
StuM
Is there a fuse on the back of the unit - might be worth checking that it you've not already done so.
Stu M
JiMR2
Aye, check the fuse on the back... otherwise try disconnecting it completely again and leave it to one side for 10 mins. Hooke it back up and fingers crossed it'll fire back up. Id unplug and check all the pins are clear from any debris also... you never know...   s:roll: :roll: s:roll:
AKA Cinnamon Jim
tigracat
If it was the fuse I very much doubt that it would display the time, I would recheck all the wiring and make sure none of the pins have bent in the connectors.
                              Mike
02 mr2 in silver with ht, mags, quad exhaust, pioneer cd, dvd double din player, debadged and de pre catted, custom arm rest, Style bar, dev keyhole covers, K&N cone air filter.
Suzuki Bandit 1200 totally mirror polished show bike.
09 Mini cooper s.
2011 Mazda Miyako 2l
StuM
The clock might take a different power feed I guess.
Stu M
Goeman
Car stereos usually have a constant power and a main ignition power supply. The clock possibly runs off of the former.
Russell
wbarrwebster
Hi,
The Clock will be on the constant wire.
Suggest you pull the plugs out of the back, put a tester on to establish constant live and switched live... (probably red and yellow)
Also, check out your earth is ok (probably black).
If all  is ok on the incoming loom..something's a miss with the HU!
IMO, you've screwed up the wiring/fuse somewhere.
B
W. B. Webster
cclarke99
On the standard loom
Blue/Yellow is power all the time from the RADIO 1 fuse
Grey is power when ignition is on, from the RADIO 2 fuse
Ground is Brown
Fuses are in the fusebox behind the dash
