blister's on alloys??
Started by Anonymous, March 12, 2004, 13:40
has anyone else had problems with there standard alloys?
mines have started to blister and look awful!
im told its a comon prob with toyota as i know a celica driver whos had three sets of alloys under his waranty!
i fancy gettin bigger wheels now
will 18'' wheels fit ok??
  s:?: :?: s:?:    s:?: :?: s:?:
It is a common problem - if you use the search facility at the top of the page (top right of the forum) you will find more information about it.
Yep... blistering is a well known problem.
You could get them replaced under warranty, or get them refinished in something tougher.
As for 18".... think it's pushing it a bit.
aarongr
Sorry to hear you are suffering from the alloy corrosion problem. More info can be found on the sticky for this section, via the search function or more recently in the following thread  http://www.mr2roc.org/forum/viewtopic.php?t=2598
I have also moved the start of the 18" alloy fit discussion to the Appearance forum.
Lusaka
