Only One Speaker
Started by uktotty, July 6, 2010, 13:11
So yesterday I had an issue where the drivers side speaker stopped working.
Played around with it and teh head unit is certainly sending out stereo to that speaker.
Today I opened the drivers window and speaker worked, close the window the speaker goes off!
What's that all about then?
wbarrwebster
Russ,
As I'm sure you've sussed, the window must be pulling the Speaker wires.../
Try and indentify the speaker wires as the go through the door and gently push/pull, just might  remedy it...
Other than that..get the door card off and resite the wires.
B
W. B. Webster
nathanMR2
Have to got a splitter box in the door. After time my wires seem to come loose and i have to tighten everything back up again
stargazer30
Quote from: "nathanMR2"Have to got a splitter box in the door. After time my wires seem to come loose and i have to tighten everything back up again
Top tip - don't use spade connectors on the wires/crossover.  Instead tin the wires with a soldering iron and then tighten up the screws.  The solder compresses and the screws don't come loose.
