Alarm goes off randomly
Started by vatovey, July 21, 2010, 11:26
vatovey
Morning all,
Was hoping someone could help, my alarm keeps going off randomly, I've tried dead locking with microwave sensors, and i've tried reducing the sensitivity by adjusting the control unit behind the drivers seat, but it still keeps doing it.
Is there any other diagnostic checks I can perform to get to the bottom of the problem ?
Thanks, Vaughn.
SimonC_Here
Try three button presses to lock the car. The last one disables the sensor.
If it still goes off it may well be the boot (engine lid) switch. There used to be a thread about adjusting it on here somewhere.
I fixed mine by bending the switch up 5 degrees, the heat of the sun expands the metal on the boot/bonnet and the switch is armed. easy fix and free
vatovey
just tried bending the boot and frunk switches upwards... will monitor, I suspect this solution will fix it tho'  s:) :) s:)   thank you  s:) :) s:)
UPDATE : The bending of the boot and frunk switch brackets did indeed fix this fault   s:D :D s:D
