New Headunit Fitted, Aerial Wont Extend
Started by The Gimp, August 18, 2010, 22:33
The Gimp
Hello All,
New to the club and found many resolutions to my MR2 issues in the past thanks to this site, thought I'd sign up and get involved.
Basically, I have installed my new Headunit, using the basic 2 socket ISO wiring harness.
Headunit works great, still have 2 spare sockets on the car wiring, which I'm guessing one will be to power the aerial?
How do I get the aerial to extend for me to use radio? Or is there an easy way to swap the aerial?
Many Thanks in advance.
The Gimp (Shane)
TF054
Facebook: Clicky
cclarke99
The black wire in the car wiring which is in the plug going to the headunit is the one that controls the aerial
The Gimp
Quote from: "cclarke99"The black wire in the car wiring which is in the plug going to the headunit is the one that controls the aerial
Thanks for the response. Been looking around the forum and come across this (should of looked properly first)
But I still cannot find an answer as to where I wire the black one... what cable on my headunit?
The Gimp (Shane)
TF054
Facebook: Clicky
SteveJ
That would depend on what head unit you have - our mind-reading skills are not that great   s:wink: :wink: s:wink:
The Gimp
Quote from: "SteveJ"That would depend on what head unit you have - our mind-reading skills are not that great   s:wink: :wink: s:wink:
Lol my bad ... I have the Pioneer P4100 DVD Double DIN unit.
The Gimp (Shane)
TF054
Facebook: Clicky
 m http://www.pioneerelectronics.com/Stati ... al0128.pdf m
Page 7, looks like you need the Blue/White.
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
The Gimp
So, correct me if I'm wrong and feel free to insult if this is an obvious question lol.
Is it as simple as wiring the black to blue/white, then when headunit is powered, then aerial will extend?
The Gimp (Shane)
TF054
Facebook: Clicky
JiMR2
That sounds correct from what I remember from doing mine.
Make sure you've got the antenna pin cable plugged into your new HU!   s:oops: :oops: s:oops:   made that mistake myself, got power to the aerial, but no reciever!  s:D :D s:D
AKA Cinnamon Jim
The Gimp
Quote from: "JiMR2"That sounds correct from what I remember from doing mine.
Lol Antenna is already plugged in  s:D :D s:D
Thanks again matey!
Looks like I got some work to do  s:) :) s:)
The Gimp (Shane)
TF054
Facebook: Clicky
skinz
whack it on a rocker, dnt want aerial up unless using radio - so uncool blasting cd with aerial up - lol   s:P :P s:P
Quote from: "skinz"so uncool blasting cd with aerial up - lol   s:P :P s:P
So uncool using cds at all these days.  s:wink: :wink: s:wink:
cclarke99
To find the right wire just use a meter to measure the voltage on the spare wires coming out of the HU as you switch it on/off and pick the one that does what you want the aerial to do
skinz
Quote from: "nelix"So uncool using cds at all these days.  s:wink: :wink: s:wink:
Lol ive act got a usb slot thingy, but qualitys better from a dics for some reason
The Gimp
Yeah going to give the Aerial thing a go on the weekend.
Lol, all mine is controlled via my Video iPod... music and films streamed to the screen  s:) :) s:)
Most CD's will be better quality, dependant on how the mp3s are ripped and what quality setting is used...
The Gimp (Shane)
TF054
Facebook: Clicky
no1trancefan
Ive got same problem, with my  PIONEER DEH-X3500Ui, antenna isnt popping up, didnt even think about it when fitting HU. Have to take it all out weekend to do the black wire to blue/white wire. The blue/white wire is wired to the remote line to my amp. Pain in the arse taking it all out lol.
JiMR2
Can you not get your hand round the back of the head unit whilst its fitted? Should be easy to see using a small mirror...
AKA Cinnamon Jim
Russel Nash
Might be helpful?
 Standard stereo connections with black wire position indicated.
Pavett1990
just my 2 pence.. but on my sony CD player there is a button that says AP/TA this on mine controlls the airel? do you have this button?
no1trancefan
(editeD)
pill20
Quote from: "Pavett1990"just my 2 pence.. but on my sony CD player there is a button that says AP/TA this on mine controlls the airel? do you have this button?
i had this on my Sony Cd player ! Very clever little thing push a button on the radio and every time i switched to cd , BT, BT audio the airel popped up and down! no mod needed i was very happy !   s:bounce: :bounce: s:bounce:
no1trancefan
Quote from: "pill20"
nice!
