Facelift Headlight Bulbs
Started by uktotty, August 18, 2010, 23:41
What do I need and what is the connector on the  back?
bump
Someone must have a facelift car?
I'll tell you when I get home
OEM low Beam are H7 55W, high beam HB3 60W.
They are both very different. The high beam has a built-in plug that goes into one of those big wired socket things, whereas low beam is "basic" 2 pin into small socket, though it does have retaining tabs for the positioning spring.
All in all you just need to look for H7 or HB3
thanks v much.
Have ordered a pair of each
So is the projector bit main or dip ?
Quote from: "uktotty"So is the projector bit main or dip ?
It's the dip
Porsche 718 Boxster
Fiat Panda Cross 4x4 Twinair
Triumph 1200 Thruxtom RS
Ducati 900SS
Cheers Nic,
All wired up yesterday, just seems that the dip beam is brighter than the main beam!
Wonder if they are wrong way round! LOL
ass about face on the wiring then??
muffdan
That's the problem Russ! Your wiring turns the projector off when you go main beam. On post facelift, the projector should stay on. The main beam just boosts what the projectors are already providing.
There you go Jason.
Main beam and dip beam on at the same time  s:) :) s:)
I just didnt know which biulb did what so I inverted it and have main beam on dip and dip and main beam on main beam.
Will be swapping the wires over tomorrow, you can have a look on Monday.
ex-member
glad you got it fixed Russ - really couldnt be arsed with the hassle myself, but glad they worked out well for you  s:) :) s:)
