auto h/u switch?
Started by Anonymous, March 16, 2004, 20:04
is there any gadget out there which will automatically switch speaker outputs between a h/u and another sound device
i don't mind even if it is a manual switch especially if i can get it to control the power switch between the two items
yeah it's a switching box normall under the AV acsories ! plug in mulitples soruces and then you can select which one you need
crankshaft
Are you switching the Speaker connections or the line-in to the amp feeding the speakers ???
It appears from you post that you want to bypass the amp and connect directly to the speakers ??
2001 SMT - Pete
to be decided but probably switch before the amp
i.e   h/u -----switch--------amp---------speakers
other input
errr  s:?: :?: s:?:
i dont get it sorry you mean a swtich to turn the amp on and off  s:? :? s:?
I think what adz means is he wants to switch two (audio) inputs into one amp, it's just his diagram came out a bit erm.. wrong  s:) :) s:)
Like this:
H/UNIT
SWITCHER----AMP----SPEAKERS
2ND INP
 s:) :) s:)
thats the one
sorry my little diagram came out all wrong
yeah it's just a standard switch AV box try carudiodiscount.co.uk
they may have some if not phone then up and see if they recomend anyhting else
But poeple do use the Av controller box'es for say adding a PS2 or mp3player etc etc so it's not un heard off
cheers buster i will give them a shoot once i have got the new h/u and have finished building the secondary input
