My New Head Unit
Started by inert2k3, September 18, 2010, 23:08
inert2k3
Just got a new head unit (currently have the stock Sony unit)
I have read up about making the swap from a double to single din unit (and thanks to Custard and totty for their advice too)
I got in touch with Chris, but he wasnt sure of part numbers
Am I right in thinking that the only two parts I need are:
55521 -16030 : Tray / Storage slot
55423 - 17040 : Surrounding trim
and a Toyota to ISO connecter (from eBay)
Will this 'surrounding trim' part mean that there wont be an ugly gap around the edge.
Many thanks
Mohammed
02 MR2 Roadster]
Wanted]
Coming soon]
Facelift trim will tidy it.up mo
inert2k3
Right i dont think ive got the correct part numbers here as the threads ive read say that the extra bits are about 8 or 9 quid each.
Just got quoted £19 ex vat each from ctp!!
02 MR2 Roadster]
Wanted]
Coming soon]
I have that exact same head unit and I am very pleased with it for the price.  The USB memory stick input is a definite perk  s:) :) s:)
I got the Autoleads fascia surround which gives you a neat little undertray and is very easy to fit, similar to this
 m http://cgi.ebay.co.uk/FP-11-03-Toyota-M ... 255a298513 m
As it's a Sony unit it will plug straight in and you won't need to use the Toyota ISO connector
Quote from: "inert2k3"Right i dont think ive got the correct part numbers here as the threads ive read say that the extra bits are about 8 or 9 quid each.
Yeah mine was about £15 3 years ago.
Get some pics of the parts mate, you have seen my interior, and you need the facelift trim part
inert2k3
Thank you for all your help
So I'll get the ebay autoleads fascia, and the facelift surround from CTP to tidy it up. I wonder if anyone is likely to have a facelift surround (doubt it) going spare?
Maybe worth a post in wanted
Thanks again
02 MR2 Roadster]
Wanted]
Coming soon]
inert2k3
Right -
Ive now got hold of the single din fascia (with the little built in tray underneath) and the facelift surround.
I was gonna have a go at fitting this weekend, but can anyone tell me if the aerial will stay up even if Im just listening to CD's after I install the new head unit?
There seems to be conflicting info regarding this and some people suggest fitting a switch to manually control the aerial?
Any ideas - thanks
Mohammed
02 MR2 Roadster]
Wanted]
Coming soon]
inert2k3
Oh and Id much rather not have to fit a switch if at all possible?
02 MR2 Roadster]
Wanted]
Coming soon]
JiMR2
If stereos on, aerials up. stereo off, aerial down.
2 options,
either dont connect the aerial pin up = no signal so will stay down.
Fit a simple rocker switch to it.
I opted for the rocker switch when i made the kick panels, check out the thread in the How To section Mo!  s:D :D s:D
AKA Cinnamon Jim
inert2k3
Sorry If im being slow here but:
At the moment, the aerial doesnt go up when im listening to CD's... only when I put the radio on.
Are you saying that after I change the head unit, the aerial will always be up even when Im just listening to a CD (unless I fit that rocker switch)
Cheers   s:D :D s:D
02 MR2 Roadster]
Wanted]
Coming soon]
JiMR2
In that case disregard every thing i said !   s:scared: :scared: s:scared:
Uber weird... When i had the stock one in, if stereo ON (cd or radio) = aerial up... hence having to fit the button as i never listen to radio n def didnt want the aerial up..
Im not sure then Mo... id change the HU over and see what happens... worse comes to worse just fit a rocker switch, just 1 cut in the aerial wire, 2 connecters to crimp on, 1 rocker switch job done...
AKA Cinnamon Jim
Jigwar
Pre- versus Post- facelift difference. Sony stereo keeps the aerial down when not in use, but no other HU seems to.
Jigwar
Past: \'51 plate
Present: \'06 plate TTET\'ed
