Help needed to connect heated rear window electrics
Started by Anonymous, October 4, 2010, 20:04
Hi, I've recently bought an MR2 with hardtop and don't know how to get the heated rear window top work when I fit my hardtop?  Any suggestions please?
Hi, in the luggage comartment behind the drivers seat, remove the panel to your lhs as you look into the compartment. You will have a seperate electrical connector for the hardtop, it may be attached to your hard top or already in situ in the luggage compartment.
You need to disconnect the wire for the soft top and plug in the wire for the hard top in its place, the other end plugs into the hard top.
There is a diagram in the owners manual. Can be tricky the first time, add your location and someone nearby may be able to help.
Gif
It should come with a spare lead to attach the hardtop to the car's electrics.
The plug on the hardtop is on the side panel behind the driver's head and it plugs into an eletrical connector behind the side trim panel in the rear storage box behind the driver's seat.
Audi TT 200 Tfsi Roadster, Ibis White, Steptronic, Bose, Nav, Climate, Telcon, Nappa Leather
Ex BMW Z4 sDrive30i Auto, Titan Silver
Ex MR2 Roadster, Sahara Sun, Black Leather, Air Con, TTE exhaust
Ilogik
piece of piddle, remove the plastics on the cubby hole, take the wire from the hard top and plug it in where the softtop wire goes, plug the softtop wire into the blank slot Whole process takes 10 mins. Think you can get away with just removing the inside cubby hole plastic.
You will need the softtop up slightly to allow for you to get the wire through.
Ex: TRD stage 1 TTE Turbo
Gif
Quote from: "nelix"remove the panel to your rhs as you look into the compartment.
LHS ???
Quote from: "Gif"
LHS ???
Lol, correct.  s:oops: :oops: s:oops:
